Dell Inspiron 1525 Laptop Logo
Anonymous Posted on Nov 26, 2012
Hi, i have a dell inspiron 1525, and when ever i plug the charger inside the laptop, my touchpad mouse stop working and also anyother other external mouse i do plug it in, when i take the power off everything work perfectly, can anyone help
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Dec 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
903
Points
16
Dear pls. reples the power adapter and tek the brand new dell adapter soon
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 08, 2008
SOURCE: Touchpad problem =[
Hey, I have the same problem.. Have you been able to fix the problem?
SUNILVOIP
Sunil Pratap Singh
  • 250 Answers
  • Posted on Dec 02, 2011
SOURCE: Hi I have a dell inspiron 1545 laptop and when I use battery power the mouse pad works perfectly , but when I plug in to the mains , it sticks , is eratic and does not work properly please help.
May be your Power cable is faulty.
Tip
1- just use another cable and check .
2- Use another power socket, may be earthing will be issue here
Anonymous
  • Posted on Jun 25, 2012
SOURCE: How to fix Dell Inspiron 1525 touchpad
Try a hairdryer
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
Hi my touchpad is not working...
it would be easy for you to get a usb mouse.you can just borrow and install the dell touchpad drivers from dell support website.this sould be fixed.
1helpful
2answers
My cursor on my Dell inspiron 1525 laptop is stuck in the middle of my screen the touch pad isn't working either I was wondering how i could fix this
Try an external mouse. You might have to turn off the touchpad in BIOS (F2 key on boot will get you into setup). Look for Mouse/Touchpad under 'Post Behavior' or perhaps elsewhere (differently displayed in various BIOS setups).
2helpful
Must disable touchpad
Is the problem being caused by your palm hitting the surface of the touchpad? This happens with many people. There is a setting for the touchpad which will let you set how sensitive the touchpad is, thereby eliminating your problem.
1helpful
Dell Cursor Typing Blinking Problem
this is because you must deactivate your touchpad. you can do this by holding the Fn key and pressing the F* key that shows a picture of a touchpad in the same color as the Fn.
or you can go to control panel and turn it off in the mouse settings. but just attaching a mouse will allow the touchpad to stay active and therefore still be sensitive enough for your hand to "tap" th cursor.;
Good luck and pls rank this response! :D
6helpful
3answers
Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
7helpful
6answers
Touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
