Question about Canon PIXMA iP4000 InkJet Photo Printer
Paper jam error in the output does not allow printing
The printer was operating perfectly when suddenly the problem happened.
When the IP4000 printer is ordered to print, the printer stalls and does not initiate printing. An error message appears: Paper jammed in the output.
BUT THERE IS NOTHING IN THE OUTPUT. I checked thouroughly.
Also, when You open the front plate the printing plate tries to move to the middle but returns to the right side.
I reinstalled the original driver, reinitiated the PC and cleaned the printing area without any results.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I am getting service error 5100 while trying to print page..the page passes through but nothin is printed....suggest me a solution????
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
97 people viewed this question
old marine
old marine
