Question about HP 910 Plain Paper Inkjet Fax
What is error 244 I m getting - HP 910 Plain Paper Inkjet Fax
  • 1,800 Answers
244 Expired ink,
Posted on Jan 09, 2009
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
E2 error on pro form 730 key in belt and motor run about 5 sec and shuts down sensor light blinks but not a steady light
Dear Sir:
I will try to help you, use the patience and carefully: need screwdriver, hex, allen+Dvom(DigitalVoltemeter)
Optic Sensor
Motor
motor brushes.
Other
board, marked U5. .
continuity.
Troubleshooting: ERR 2 - No Motor Movement
Turn unit power off and then on to clear the ERR2 message from the display. To test whether the drive
board is putting out power to the motor, insert multimeter probes on the M+ M- connectors and press
the speed up key. . (Note: To avoid ERR2.)
Power to Motor
If the drive board puts out power to the motor, but the motor does not operate, either the motor wires or
motor is malfunctioning. Test wires for continuity. Inspect connections. Perform an ohm test on the
motor . Inspect motor brushes.
No Power to Motor
If there is no power to the motor, either the signal is not arriving at the drive board, the transformer
or inductor is bad, or the drive board is bad. Inspect the following:
??? Display - Does the display beep when you press speed up? If so, the display has sent its signal.
If not, inspect overlay-to-display connections. And press down on the main program IC, marked U5.
??? Wires and their connections - inspect data cable connections from the display to the drive board,
test data cable continuity, inspect M+ M- wires from the drive board to the motor.
??? Inductor (6310 only) - inspect inductor and its wires and their connections. .
??? Transformer - inspect the transformer and its wires and their connections.
??? Drive Board - inspect the drive board for burnt or cracked components. Inspect LEDs (See DRIVE.03
and DRIVE.04). Press on the drive board IC chips to ensure good connection. If the power indicator on
the drive board, LED8, lights, but there is no power to the motor, and other components are good,
replace the drive board.
wITH THIS YOU FIX IT. If you need further assistance, please reach me
SINCERELY. GOD BLESS YOU.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 20, 2011 | Exercise & Fitness
Error code ld
This error code indicates that drain times are longer than expected.
Click the following to learn more about proper drain systems for BravosTM washers. The example shown is for an impeller washer but is applicable to washers with agitators.
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 39" (99 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and both of the questions above have been checked, call for service.
Hope this helps.
Jun 29, 2011 | Maytag Washing Machines
For a4tech webcam pk333e model, how can i get a real clear image?at night,even with sufficient lightning, the image is red and looks like night vision.please answer me asap.thanks.
cho A4TECH webcam pk333e mô hình, làm th? nào tôi có th? nh?n ???c m?t hình ?nh th?c s? rõ ràng vào ban ?êm,? ngay c? v?i sét ??, hình ?nh có màu ?? và trông gi?ng nh? ?êm vision.please asap.thanks câu tr? l?i tôi.
Jun 28, 2011 | A4tech Office Equipment & Supplies
I have Hp Desigejet T1100ps and its showing the error code of 47:01
Description:
Star wheels motor error..
Corrective Action: Try the following:
???? Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
???? Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
???? Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
???? Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
???? Replace the Starwheel Motor → Page 8-167.
???? If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
please rate my answer
i hope this helpfull
Dec 30, 2010 | HP Designjet T1100ps Printer
My router is displaying the following characters when...
HI ,
  • This is due to which IOS u have Uploaded got corrupted or Flash got Corrupted
  • If you are able to go to ROMMON Mode Please upload the IOS through XMODEM Otherwise
  • Please change the FLASH
Sep 25, 2010 | Cisco (1841) Router (cisco1841)
I WANT TO INSTALL TALLY 9 AND USE IT WITH OUT INTERNET CONNECTION WILL IT BE POSSIBLE. HELP
To activate your license offline follow the steps shown: Go to Gateway of Tally ???? Press F12: Configure > Licensing > Offline > Activate The Activation Form appears ???? Enter the Serial Number in Serial field ???? Enter the Activation Key in Key field ???? Enter the Email ID in E-Mail field ???? Tally displays a message indicating that the tally_req.lic file has been successfully generated. ???? Copy tally_req.lic file available in the Tally folder to a floppy/CD ???? Paste tally_req.lic file to another computer with Internet connectivity and Tally installed. ???? Start Tally ???? Press F12: Configure > Licensing > Offline ???? Select Send External Request to send the request file to Tally Licensing Servers. The response file called tally_resp.lic is generated and saved in in the Tally folder. ???? Copy the tally_resp.lic file to a floppy or CD and paste the file into the Tally folder where the license has to be activated. ???? Start Tally ???? The Register Now screen appears, ???? Press Enter to work on Tallly
important:if this information was helpfull to you please vote for me and write a comment for me.
Sep 02, 2010 | Computers & Internet
I'm getting an error 244 or 223 when receiving a fax. the fax only partially prints out
Error 244:
Definitions
  • The user of the remote machine pressed the Stop key, causing the session to be prematurely terminated.
  • The remote fax machine determined that there was a feature incompatibility between the two machines and terminated the session. For example, the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solutions
  • Make sure that the remote machine can accept and use polling.
  • Select a slower reception speed.
Error 223:
Definition
The local machine was unable to receive an entire page even after multiple attempts to receive the parts of the page that contain errors. This situation is usually due to extremely poor line conditions.
Solutions
  • Try to receive the fax at a different time when telephone line conditions have improved
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hp laserjet 3050 fax report
The error 244 results from a fax machine communicating and trying to 'Poll" your fax. (receive information you have loaded into the fax memory for all to receive) The error comes in when your fax has no information or is not set up to be polled.
Look in your menu for the "ECM" setting on the printer menu. If this error is getting persistent change the ECM setting to the opposite of what it is set now. More than likely your fax will say ECM=On, change to off.
If you have problems locating where the ECM section is, print a "settings report" or "printer menu".
Hope that helps you.
Sep 02, 2008 | HP LaserJet 3050 All-In-One Printer
HP 910 Plain Paper Inkjet Fax Logo
296 people viewed this question
Seeker5211
Seeker5211
