Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hi sir i have a problem that  how to share the individual internet connection on other pcs
  • 30 Answers
To share the induvidual internet connection with other pc s you need the following:
1. The pc which owns the internet it need an ethernet connection too.
2. The other pc's which dont have internet connection it needs
3. You need an equipment which connects the internet pc and
other pcs. It called Ethernet switch.
Linksys company has a good product, which can connect 4 pc together, called linksys Wrtg54gl. It not only a small switch
it also has the capability to connect wifi devices.
Buy this router connect the pc-s to thos router with ethernet switch. You need to set up ip addresses for the pc-s.
The whole procedure is well written in the Linksys admin manual.
I hope it helps.
Here is the router manual:
If you dont need the wifi router (you dont need wireless connection buy this model:
Linksys BEFSR41
If you need to connect more than 4 pc it requires a new solution.
If all pc are connected with ethernet together, you need another solution.
If you has a problem with this write to the forum, i will respond you.
Posted on Jan 09, 2009
I already have 2 PCs that are both internet sharing using a non-router 5-port hub (one with WinXPPro that's connected directly to the internet, and another with Win98SE that's connected using a proxy). Now...
You can't share your connection on the PS2 to other devices. Connecting the PS2 into your hub should share the connection to all three devices as normal.
Jul 13, 2009 | Sony PlayStation 2 (PS2) Console
Connecting internet to ps3 using sprint air card
Do an ICS (Internet Connection Sharing) between your PCs. With Windows, its under the Network Connections Icon on the Control Panel. It'll show your different ports, to different devices (ie. cables to other PCs, or internet) Give them IPs by right clicking their icon, select properties, then find TCP/IP and select properties again and making your own IP numbers. Then find your internet connection one, right click, select properties, then a VZaccess screen will appear, select advanced and the properties screen like the others will appear. Then click advanced and select the ICS option and which connections you want to share.
Jan 17, 2009 | NetGear WGR614 Wireless Router
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of and a subnet mask of
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Internet Sharings
first of all can u plz tell me how do u connect to internet like u use a connectiode or something if yes its very easy u just need to right click on the connectiode & just go to properties click on the advance tab & under the internet connections sharing put the check mark on allow other network user to connect to internet through this computer internet connection thats it. u will be able to access the internet on all the pc on ur network. incase if u still have any problem just let me know & also provide the details on ur network like how u connect, any router hub or switch is been use for connecting pcs etc
Oct 02, 2008 | Computers & Internet
Internet connection sharing
To share an internet connection, you need to have two network connections, one for the internet connection, and another for your network.
If your DSL has a USB connection, plug it into one of your computers and then then go through the network setup wizard, from there it will walk you through sharing an internet connection.
If all the computers have wireless, you can set up an adhoc network, and share the connection that way.
Honestly, the easiest method would be to go out and buy a router.
Aug 24, 2008 | Microsoft Windows XP Professional With...
Modem problem in workgroup
Enable your internet sharing protocol so that the other workstation can connect to the internet...
Try configuring the ip address as well as the gateway of your worksation...
Aug 06, 2008 | Computers & Internet
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
277 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
