Question about Dryers
Whirlpool dryer model GEW9868kt0. Has no power acts like it?s unplugged. The outlet meters out with 240V has power going into the dryer. Switch on door appears to be good but before it broke dryer stayed on with door was opened. Took switch off and hardwired wires and still did not work, not sure if that was a good test for the switch. Any Ideas?
  • 706 Answers
Hello bobberville,
Some switches are made to open the electrcal contacts when the actuator is pressed so since you mentioned the switch broke.. and you hard wired it shorted together.try unhooking those wires from each other ( probably not gonna fix your problem but a simple test).. The other more likely candidate is the non-resettable fuse used on many dryer models... once that opens.. the dryer stops doing dryer things.. It will need to be replaced
http://www.pcappliancerepair.com/model-display.php
use this link at look at item 59 ( thermal fuse).. it may be your problem...
Hope this helps...
Regards
Rick
Posted on Jan 09, 2009
I HAVE THE WHIRLPOOL LER4634JQ0. IT SAYS 120V/240V. CAN I USE IT AN APARTMENT ?
Is your apartment wired with a 240V outlet? Ask your landlord. A regular outlet is 120V. Electric dryers use 240V, thus where you are plugging the dryer into has to be a 240V outlet.
http://www.appliancepartspros.com/
Feb 09, 2011 | Whirlpool LER4634J Electric Dryer
Amana Model NED7200TW front load dryer just shut down, no lights anywhere, acts like total power loss, unpluged and checked outlet with meter and both legs show 199 volts. Is there a reset or fuse that...
I have the same dryer and the same problem. The machine was bought at Home Depot as a housewarming gift by my parents. It was less than a year and half old at the time it completely shut down. I have been fighting with whirlpool over their inability to fix the problem for almost 4 months now. In my opinion this is a major defect and the machine should be replaced regardless of the warranty status.
Nov 07, 2010 | Amana NED7200TW Electric Dryer
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Jan 09, 2010 | Kenmore Dryers
The dryer is not heating
Hello there here is a list of things to check
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
Jan 09, 2010 | Dryers
I have a whirlpool dryer that will not start when the start button is pushed....thanks.
Good day,
The first thing to check, is to see if the machine is getting power.
On a gas model, it is simple. Unplug the power plug, and plug another device into it and test.
For electric, you will have to unplug, remove the power outlet cover, and check with a meter.
1. If you hear nothing at all, it is probably the door switch. Remove the filter screen, remove the 2 screws under it, and with a screwdriver, pop up the 2 corners of the top and rotate the top up. Careful. Do not go above vertical.
The switch is on the top right. Remove the wires and with the door closed, check the continuity with an ohm meter. The resistance should be zero. if not, replace.
2. When you press the start button, and hear a constant hum, it usually indicates a bad motor.
3. If all of the above check O.K. the timer is faulty.
Dec 02, 2009 | Whirlpool Dryers
Dryer will not heat but will run.
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 10, 2009 | Whirlpool LER5636P Electric Dryer
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Whirlpool Cabrio Electric Dryer - No Power
you have to send the model number off of the dryer,also if the dryer hasn't been taken apart and cleaned out also the vent line it could be clogged with lint and you could have popped the thermal fuse or something like that,you'll need a meter,unplug it take it apart and check the t-stats to see if one of them popped,or if it has a belt switch the belt could have broke but if you want to fix it send the model number and more info like any lights coming on but it won't start?if so then you know power is coming to the dryer but it won't start stuff like that.
Dec 26, 2017 | Dryers
Whirlpool dryer
    You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool surpreme heavy duty not responding
Bob, if you have a voltmeter start at the terminal block where the power cord hooks up. Should have 120V from each end terminal to center terminal and 240V across the two outside terminals. If you don't have this the problem is in your outlet or breaker. If you do have this check first the thermal fuse, I will attach a photo for you. If you have a meter it should show continuity. If you don't have a meter you can temp. hook the two wires going to it together and see if the dryer starts. Do not leave it this way and make sure to unplug the dryer before hooking the wires together. This is a safety device and you need to replace the fuse if it's bad. Check these things first. Catriver...post back.
Sep 20, 2006 | Whirlpool GEW9878LW Electric Dryer
Dryers Logo
178 people viewed this question
Top Dryers Experts
