Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
Model# m30 trips breaker after ignition older unit need parts manual
Plastic impeller insert broke changing the load on motor&over loading breaker still dont know part numbers need manual.
Posted on Jan 12, 2009
What voltage and amperage is required to trip a shunt trip unit
The circuit breaker will have a shunt trip voltage & current ratings, a variable current selector knob, etc. - based on the type breaker (Catelog number). Here is a link to images of C-H shunt trip devices and circuit breakers
cutler hammer shunt trip circuit breakers parts Google Search If you can provide the catelog or model number - I 'll be able to provide add'l help.
Mar 11, 2014 | Eaton Electrical Supplies
Hotpoint gas oven doesn't light
What is the complete model number of your unit?
Dec 09, 2012 | Kitchen Ranges
I HAVE XB10 HVAC SYSTEM TRIPS BREAKER
could need a start assist for compressor or could be weak breaker
Dec 03, 2012 | Heating & Cooling
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2289AEQ/1266/0165000/M0406284/00012?blt=06&prst=&shdMod= here is a simplified wiring diagram for your unit. It might help you track back the problem.
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I inherited an older model whirlpool electric dryer when I moved in...there seems to be no heat...went to get clothes out this morning and they were still damp...I wasn't given a manual - and have...
Check the breakers, by FULLY turning it off and then back on. What happens, commonly, is the heat side of the 220 breaker trips. If it keeps happening, sometimes you need a new breaker, but DO NOT increase the amp rating of the breaker. Breakers that trip from time to time, eventually start tripping EARLIER.
Jun 10, 2011 | Whirlpool Dryers
My dryer runs and drys but after a little while it will trip the breaker in the electrical panel. Anyone have a clue? It's a GE mod.# DLLLR23EG1WW. Thanks in advance for any help. Tom
Hello, W/D here.
When a machine is operating properly, but then trips the breaker, the breaker itself seems to be suspect. Breakers wear over time, and can become "weak". Also, amps on a breaker are time weighted. The more amps that you pull, the less time it takes for the breaker to trip. This is also true with a weak breaker. Check the amps that you should pull with your dryer, and check the breaker. If the breaker is the correct size, try replacing it. You should be on a 30 amp breaker/circuit.
Here are some useful links for your dryer:
Owner's manual http://www.managemylife.com/mmh/owner_manuals/6276/GE-Residential-Dryer-L0707113?brand_name_search=DLLLR23EG1WW+GE Installation guide accessible from same link.
Parts manual http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DLLLR23EG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DLLLR23EG1WW
Best regards, --W/D--
Apr 07, 2011 | Dryers
I have a older model trane we had thnder storms yesterday and the breaker tripped hit the breaker but i get no cold air
check the fuses at the disconect prob blew them they are outside by the unit prob a grey box follow the wires from the condensor
Aug 20, 2010 | Heating & Cooling
Machine will not work, motor hums
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 08, 2009 | Kenmore Washing Machines
Air compressor trips breaker
check the ground wire most common mistake
Nov 18, 2008 | Air Tools & Compressors
Runs but not heating up
The manual says it could be one of the two house fuses in the unit. My question is where are they located .
Apr 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
124 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
