Question about Toshiba Satellite M105-S1021 Notebook
Cant install two emory modules as can only find one slot!
Just received two 1GB memory modules to upgrade my Toshiba Satellite M105-S1021 laptop, problem is, I can't see where the standard RAM is to remove it to add both. Have installed one of the modules and is working fine but would really like to remove the standard 512mb to upgrade mine to the maximum so any help would be greatly appreciated.
Have researched loads on the net the past few days waiting for them to arrive and it has said on numerous sites that I have two memory slots, hence why i am so confused.
Thanks,
Steve
  • stevie_g1980 Jan 09, 2009
    Done that but to no avail. Read somewhere that i can remove the standard RAM but when I removed the cover to install the ram I couldn't see two slots only one, thanks for the help
    Problem Solver:
  • 10 Answers
I hope you have not gave up on your problem. Your Notebook is equipped with two memory module slots. One slot is user accessible ( under the notebook) , the other slot sits beneath the keyboard under a EMI shield (Electromagnetic interference Shield). All it requires is the removal of the panel where the power button is at and two screws that hold in the keyboard. If you are uncertain of performing this task, any local Certified computer shop can perform this in 5 minutes.
if you think you can tackle this task it is not hard and i have detailed photo's if you need them.
Posted on Jan 27, 2009
  • Eugene Orozco Jan 28, 2009
    need photos email me. eorozcofixya@gmail.com
  • 1,800 Answers
Check th bottom of ur lap.
remove the screws.
the only place for the ram modules is there.
Posted on Jan 09, 2009
How do I replace the internal memory module on a Toshiba Satellite M105-s1021?
You should remove the memory cover underneath your laptop first. There are several covers but only one is the correct one.
The modules unclip by way of the clips on the side of the modules.
BEFORE YOU TOUCH THE MODULES ensure that the battery has been removed and you have touched the VGA output socket, to discharge yourself from static, or the modules will possibly get damaged.
Only touch the side ends of the modules, (where the fixing slots are), to avoid damage.
Make sure the replacement module/s are of the same make and type otherwise you may get problems.
I hope this helps.
Oct 22, 2010 | Toshiba Satellite M105-S3041Notebook
Where do I add memory to my Toshiba Satellite M105-S3041
There is a panel on the bottom of your laptop, with a Philips screw head andv the number "4" in a circle. Remove this screw, and the panel. Under this panel is the memory module(s), and they will take up to 1GB per module.
Oct 03, 2009 | Toshiba Satellite M105-S3041Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
TOSHIBA SATELLITE M105-S1021 THE ATI GRAPHIC HAD BEEN DELECTED BY MISTAKE
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 19, 2009 | Toshiba Satellite M105-S1021 Notebook
Memory slot #2 in the Toshiba Satellite M105 - S3074
The second memory chip is directly under the keyboard. you need to gently pry off the plastic cover above the keyboad that has the speaker grid on it. under there you will find the screws to remove the keyboard and then under the keyboard you will find the additional chip. I maxed mine out with 4gb. but since I'm only running 32 bit it only uses 3gb. If your gonna upgrade be sure to do it in pairs.
Mar 17, 2009 | Toshiba Satellite M105-S3074 Notebook
Hi there, Just wondering if someone can help me. I just received today two 1GB memory modules so I could upgrade my laptop. Only problem is, It states on numerous sites that my laptop has two memory...
Here is the link for the Toshiba Satellite M105-S1021 manual. It is zipped and you can download it to your machine. It will tell you exactly how much RAM you can hold and where it is located.
Please don't forget to rate this solution.
Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
I have a Toshiba Satellite M105-s1021. I try to upgrade from 1.5gb ram to 2.0gb ram and i get a blue screen of death. I switch the slots that the chips are in and then i get nothing but a black screen...
Dear Tom,
ITs seems that there is a compatibility issue with your new 2.0 GB Memory module, please check the frequancy of these ram.
Be Happy Always
Regards
Dec 04, 2008 | Toshiba Satellite M105-S1021 Notebook
Toshiba m105-s3084
Number of Slots:
Slot 1 Slot 2 Normally you will find the 2 slots, one above the other.
Each memory slot can hold DDR2 PC2-5300,DDR2 PC2-4200 with a maximum of 2GB per slot.*
*Not to exceed manufacturer supported memory. Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules. Make sure that both are fully seated prior to powering up the laptop.
Nov 05, 2008 | Computers & Internet
Toshiba Satellite M105-S1021 Notebook Logo
313 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
