Question about Xerox WorkCentre XD105F Laser Printer
Cannot hook up
My new computer does not have the proper connection. is there another way?
  • 1,800 Answers
Check usb cable
or com ports
or or even serial ports if available
Posted on Jan 09, 2009
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
The message says that my printer is not properly hooked up. what do i do?
Does your printer use a USB connection? Did you install the printer's driver before connecting the printer to your computer? Was your printer working before?
Jul 04, 2010 | Canon BJC S600 InkJet Printer
We have a PIXMA MP190 ...AND we need help in connecting the printer to the computer...
After proper unpacking,
  1. insert the install disk into the computer and install the software provided with the printer.
  2. Re-boot computer
  3. Hook printer up to the computer with the appropriate connector wire
  4. it is now ready for use.
If you need the quick start reference guide click HERE for proper unpacking and installation instructions. On the page provided in the link, just enter the four numbers at the top of the page and download the file.
I hope this helps and good luck!
Feb 28, 2010 | Canon PIXMA iP1600 Printer
Turned monitor on and when the cable connects to tower, the monitor shuts off. Just put in new video card and it still does it
Interesting issue. First off you should have the monitor hooked up before you try connecting or disconnecting anything. Try to find a monitor that you know is good and hook it up properly. Make sure the video out plug is indeed sending a signal, then try switching to the new monitor. If it does the same thing, you probably have a bad monitor. If you're near Rockville, MD, check me out at Inovagent. I can help you with your hardware issues.
Nov 03, 2009 | Office Equipment & Supplies
Scaner will not work? Says its not hooked to computer?
Hi! Check the cable of the scanner if it is properly hooked to your computer. Also check all the connection from scanner to the computer. Then turned on your scanner. GOOD LUCK
May 06, 2009 | HP OfficeJet r80 InkJet Printer
Hooking up a printer
Hi Sissy,
When you say you tried a hub station, what exactly did you use and what did you do? According to the setup guide, this model have an ethernet connection. Does your printer have one?
Take a look at THIS doc especially section B: Ethernet (wired) network on page 9
Jul 01, 2008 | HP Officejet 6310 All-In-One InkJet...
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
NOT CONNECTING
Hi, have you connect your OfficeJet to one of your telephone outlet using a phone cord(usually provided with a AIO printer)? Fax requires analog phone line to operate. If you have a corded phone, you could disconnect it and hook it up to your OfficeJet.
Once you got it hooked up, try dial a # to your cellphone so you know it's dialing properly.
Good Luck!
Tony
Jan 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Cant hook up my printer
first you tell me what is the configration of your hp computer and which interface are you using for connection like usb infra or parallel choose any interface and install proper drive it will work
Sep 24, 2007 | HP DeskJet 450Ci InkJet Printer
Xerox WorkCentre XD105F Laser Printer Logo
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
