Question about Toshiba Satellite M105-S1021 Notebook
Hi there, Just wondering if someone can help me. I just received today two 1GB memory modules so I could upgrade my laptop. Only problem is, It states on numerous sites that my laptop has two memory slots(the 512mb standard slot) and one additional, problem is I can't find two slots can only find one!? My laptop is a Toshiba Satellite M105-S1021, I've installed one of the memory slots but would really like to install both. If anyone can tell me how to remove the standard RAM i'd be really greatful Thanks, Steve
  • 741 Answers
Here is the link for the Toshiba Satellite M105-S1021 manual. It is zipped and you can download it to your machine. It will tell you exactly how much RAM you can hold and where it is located.
Please don't forget to rate this solution.
Posted on Jan 09, 2009
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I bought an Acer AO532h-2964 netbook, and I'm wondering: can I upgrade the RAM from 1 GB to 2 GB, and if so, which memory chip should I buy?
yes you can, your netbook can have a max of 2gb ram and a max module size of 2gb.
So you have 1gb pc 5300(ddr667) installed, and you can buy 1 more 1gb module, laptops use sodim.
Aria.com has a 1gb stick for £25
http://www.aria.co.uk/Products/Components/Memory+-+Laptop/DDR2+667MHz+PC5300/
you could also try play.com / amazon / ebay
Jul 10, 2010 | Acer Computers & Internet
Will windows 7 work on my m70 laptop
Hi
Thank you for your query
Your laptop does have the minimum spec for Windows 7, however I would recommend that you upgrade the memory from 1GB to 2 GB as it will be quite slow.
If you havent already upgraded the memory you currently have is 1 GB 533 MHz DDR2 SDRAM (2 X512MB modules), you will need to upgrade this to 2 X1GB 522MHZ DDR2 SDRAM
I hope this has been helpful.
Feb 26, 2010 | Dell Precision M70 Notebook
System can not see memory upgrade
Are you sure the memory modules are compatible with your laptop?
You can try booting and going into the Bios (F2 or Del), sometimes that helps in reconfiguring the new setup.
Oct 20, 2009 | Toshiba Satellite A105 Notebook
Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
Thanks to Microsoft Knowledge Base for help with my answer:
First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
Jul 07, 2009 | HP Compaq Presario V3000T Notebook
Can Sony VGN use single memory module?
You're gonna need two 1gb modules.
Hope this helps.
Best of luck!
Feb 28, 2009 | Sony VAIO VGN-N250E/B Notebook
Sir,i would like to upgrade my memory(256MB DDR2)for acer travelmate 4061nwlci pls inform if 1GB is compatible.pls help
Your System memory is upgradeable:
256 or 512 MB fitted as standard upgradeable to 1 GB of DDR2 533 memory, or 2 GB using two soDIMM modules.
Regards,
Mike.
Feb 23, 2009 | Acer Computers & Internet
Memory upgrade
We have the memory you need. Memory-Up is committed to provide the best memory and excellent services for all of our customers. We know that sometimes it is a bit confusing to buy the correct type, speed, and capacity of memory for your system. Therefore we hope that these tips below would help you for buying the new memory.
Memory Upgrade Tips
What is Compatibility and Memory Density Issue?
Memory module can be composed using different type of memory chips and therefore created different type of density for the module. For instance, a 512MB PC2700 DDR SODIMM memory can be composed using eight 32x16(High Density 512Mb technology) memory chips or sixteen 32x8(Low Density 256Mb technology) memory chips. As the laptops are equipped with different memory chipsets, some older laptop (chipset) would have compatibility issue working with the modules that is built with the newer 512Mb technology. Using the Not-Compatible memory will result the laptop to either not boot or only recognizing half of the memory modules. Thus that is not the correct memory for your system. Our Memory Finder and Memory Scanner will help to eliminate those problems and find the correct memory for you. We guaranteed the memory to work or your money back.
How much memory do I need?
Here are some general descriptions for different type of users and the amount of memory they would need for their systems.
Normal User: The system is mainly used for checking e-mails, processing word/excel file, and web surfing. Suggestion: 512MB to 1GB of system memory.
Power User: The system is mainly used for playing computer games, editing photos/videos, running database queries, or multi-tasking environment. (Surfing web/Processing Word/Excel File/Listening to Music). Suggestion: 1GB to 2GB of system memory.
Super User: The system is mainly used for running large number of database queries, professional editing of photos/videos, heavy multi-tasking environment. Usually a server or a workstation would be considered as Super User due to the multiple accesses from users. Suggestion: 2GB and above of system memory.
How much memory and memory slot do I have with my system?
You can download our Memory-Scanner to find out the the amount of memory that you have and the memory slots that are available for upgrade.
How many memory module should I buy?
It is recommended to purchase one module with bigger capacity than two modules with smaller capacity. For instance, if you can buy either one 1GB memory module or two 512MB memory modules for your system, it is recommended to get one 1GB and leave the other memory slot empty for future upgrade if necessary.
Note: For systems that supports dual channel memory mode, although memory modules need to be installed in pairs to enable Dual Channel Memory Mode, we still recommended users to purchase one bigger module than two smaller modules since Dual Channel Memory Mode has only a minimal improvement in the actual system performance.
What if I want to mix different memory together?
Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 256MB and one 1GB of memory for the total of 1.25GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules. We recommend users to use our Memory Finder or Memory Scanner to find the correct memory for your system.
i thnk that will helpfull for u
Oct 18, 2008 | HP Pavilion ZE5730 Notebook
Can i upgrade my MT3705 to 4GB RAM?
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Jun 12, 2008 | Gateway MT3705 Notebook
Toshiba Satellite M105-S1021 Notebook Logo
221 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
