Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
The normal and cancel blinking, dishwahser not work
I tried to turn off power and turn on after two days, but it does't help.
  • 70 Answers
This usually means a microprocessor failure. Under the lower toe kick plate is the tech sheet( some phillips head screws) and the sheet will tell you what the two blinking lights mean.
Good Luck!
Posted on Feb 19, 2009
Acer xc-215 blinking power bottom wont turn on
Please remove the battery and try to turn on the computer with the power supply. If the notebook is turned on with power, the fault is from the battery. I await your response, regards.
Feb 08, 2018 | Acer Computers & Internet
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
I have a 32 inch toshiba tv that sometimes won't turn on for days
You may have bad solder joints inside and around the power supply or deflection circuit. Whit the power on try to hit the side of the set to see if it makes a difference.That would confirm the problem.
Hope this will help Good luck.
Please do not rate this answer(unless it helps) as it is only a suggestion.
Dec 03, 2009 | Televison & Video
The light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
May 31, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Nuvi 715 no power
I have the same problem
May 10, 2009 | GPS
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
234 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
