Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I have 2 flashing error lights on my epson sx100
My sx100 is brand new and after doing some scanning today i now have 2 x flashing error lights and the printer will not work.
  • 1 more comment
  • 66tricky Feb 19, 2009
    Exactly the same issue. New printer, used scanner...fine. Tried test print to verify printer and it wouldn't feed paper. Tried time afetr time, realligning aper, shcnging number of sheets etc.... Printer went into General Error mode with ink and paper lights flashing and that's it.Help docs are useless and the utils just suggest switching off and waiting. Several hours later the error still xists. Heap of junk as far as I can tell.
  • malc41har Mar 11, 2009
    Exactly the same, two lights flashing and nothing else happens.
  • 66tricky May 11, 2010
    ps... now I remember why I haven't owned an Epson printer for about 10 years. I'd forgotten how terrible they are, refusing access to the ink carts until it decides they are empty so if any seating problem, you've had it.
My brand new EPSON ME101 flashes all lights. Not able totake any print outs.
If the printer is new, the cartridges may give less number of print outs with epson printer or the cartridges may not work at all. This problem may be because the cartridges has a resetting chip. This chip has a capacitor that is drained off over the years.
Feb 11, 2013 | Office Equipment & Supplies
Ink light and on/off light flashing
Turn printer off for a few minutes then turn back on. If still flashing your cartridges may not be compatible.
Jul 17, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson 4490 scans with colour streaks/ digital interference
did you properly close the scanner lid? these type of errors do usually occur when you unproperly close the lid wherein light passes inside causing it to reflect on the document that you are trying to scan
Sep 13, 2009 | Epson Perfection 4490 Film / Flatbed...
Epson Stylus SX100 General Error
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you.
Sep 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
EPSON STYLUS PHOTO RX425
hi if all the lights are flashing and if you have tried turning printer off and unplugging it from power supply and still you are getting the same error lights then chances are thats a hardware issue already.
call epson support so that they can assist you regarding the warranty status of your printer. Thanks for using Fixya!!
Jun 21, 2008 | Epson Stylus RX425 Multifunction...
PROBLEME OF MY EPSON LQ 2090
whene i turn up my epson, i have a bip soone and all the leds are lighing
Nov 06, 2007 | Epson LQ-2090 Matrix Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
1,555 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
