Question about Tappan TGF320 Gas Kitchen Range
WHITE FILM INSIDE OVEN
My 86 year old mother had a larges casarole splatter all over the inside of the oven. She used the sel-cleaning unit. Now there is a white like film which seems to be baked inside. I've tried oven cleaner and brillo pads at they won't even come close to touching it. Any clue?
  • 318 Answers
Your mom may have used a non-self cleaning cleaner to try and clean this oven in the past. you wont have much luck getting rid of the stain but using cleaners like easy-off or mr muscle may help you reduce the staining.
it could also be that an element has shorted out and "burned" the surface of the oven. if the oven doesnt heat properly then check the elements for a rough or burnt out area. that does happen but its probably just going to be stained as it sounds like you have tried to do the cleaning.
p.s. i like mr muscle better then easy-off.
Posted on Jan 15, 2009
I have a Turbo Chef c3 oven. When I turn it on there a black dust inside the oven. It might not be food safe to use the oven now. Please advice.
Convection Microwaves get food splatter that gets into the convection fan area in the top of the unit. it is possible it just has baked some food splatter down do powdery dust. I have taken a screw driver and held the blade and tapped the top with the handle to just bump it a bit and let the loose debris fall down, then wipe it up with a damp cloth or sponge. You dont want or need to beat on it, just knock on it a bit and see if you get any loose junk falling down. Do that until it stops dropping and then run it to let it blow the rest of the loose crud out of the top. I guess you could also take a vaccuum cleaner and suck the top grill area inside the unit. That may help too. I have mostly found it to be that baked junk but It is possible it could be rust if the unit is old. You may want to get a flashlight and take a look. I have one built in 1981 and has neever rusted so only baked garbage has ever come down.
Oct 16, 2017 | Microwave Ovens
The inside glass panel, in the oven, has a hairline crack. Is the oven still usable?
Hello ewaters56 - Honestly, I suggest contacting a professional to have the inner glass panel replaced and I do not recommend for the oven to be used.
Dec 12, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Tripped breaker while running, now it has no power
You would be better off replacing the microwave oven, it is at the end of life.To replace parts would easily cost more than a new item, plus prices have dropped considerably over the years.
Apr 25, 2012 | Sharp Carousel R530EST Microwave Oven
Our 10 year old neff U1421 has just gone bang and has blown the fuse and left a white/grey film covering the complete inside of the oven. Is this repairable and if so, what part/s do I need?
sounds like the element has burned a hole through itself,, check with a local dealer for the element,, be sure to replace the contacts at the wires when replacing
May 22, 2011 | Neff U1421 Double circotherm Electric Oven
Maytag UMC5200AAW SS # 51285923 Never had any problem until, today it sparked and a small fire out of the top of the cover on the inside top of the right wall panel. We have it built in to a cabnet...
That sounds like a wave guide cover that protects food splatter from getting into wave guide. will need to replace that cover and thoroughly clean inside of unit ans around cover. Those covers must be kept clean and dry!!!
Sep 10, 2017 | Maytag MMV5100A Microwave Oven
The inside of my self cleaning smooth top range
Using any kind of cleaning solution can cause the self-clean catalytic coating to be damaged. The glass itself isn't sensitive but don't apply anything like oven cleaner or other caustic cleaner to any of the other surfaces unless your owner's guide specifically permits it. On the glass, I have on occasion used a new single-edge razor blade to remove any heavy, baked on splatters and then conventonal glass cleaner to finish.
Sep 07, 2009 | Ovens
Deep Cleaning techniques for GE spacemaker Convection microwave
Try simple green. It is great at eating through grease. It may take a few times but it works. It is biodegardable. I used it at one of my old jobs for cleaning grease off of glass and use it in my home as well.
Apr 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cant find manual, oven probably 15 years old. How do I clean?
Use some windex. Use easy off oven cleaner on the inside of the oven. Follow directions on lable. NEVER use a feature called self clean on an oven with electronic controls. Unless you just like to spend money.
Apr 10, 2009 | Ovens
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
Removed splatter shield
The parts can be ordered from the Panasonic authorized parts rep. You have to contact Panasonic for details.
I strongly recommend to have any work on a microwave oven done professionaly. There are radiation leakage issues if the door is not re-assembled properly. After doing any service the microwave oven must be tested for radiation leaks. I doubt that you have the radiation testing equipment to make sure that there are no leaks.
From US Food and Drug Administration (Microwave Oven Safety)
http://www.fda.gov/cdrh/consumer/microwave.html
Excellent Wikipedia Article About Microwave Ovens
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Jul 26, 2008 | Panasonic NN-S753 Microwave Oven
Tappan TGF320 Gas Kitchen Range Logo
887 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
