Question about HP DeskJet 5150 InkJet Printer
Which HP printers use #56 & 57 cartridges ?
Which Hp printers use # 56 & 57 ink cartridges?
    President:
  • 8,637 Answers
Fits Models: Deskjet 450cbi ... 1350 PSC ( 57 56 HP C6657AN Ph C6656AN 57 56 HP C6657AN Ph C6656AN 57 56 HP ....
Hope this helps. Bud
Posted on Jan 25, 2009
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: When I use generic HP 56, 57, & 58 print
NO
Posted on Feb 17, 2009
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
What ink cartridge does it use?
HP 61 black ink cartridges, HP 61 tri-color ink cartridges, HP 61XL black ink cartridges, HP 61XL tri-color ink cartridges.
Jan 03, 2016 | HP Deskjet 1051 All-in-One Printer
Should I buy printer cartridge or not?
If you do not have a user manual for this printer then download one from this site. It should explain which ink cartridges types to buy and how to replace these. There are only two cartridges but based on the size you can buy different.
HP 662 Black Ink Cartridge (~120 pages);
HP 662 Tri-color Ink Cartridge (~100pages);
HP 662XL Black Ink Cartridge (~360 pages);
HP 662XL Tri-color Ink(~330 pages)
http://h10032.www1.hp.com/ctg/Manual/c03847745.pdf
Aug 05, 2014 | HP DeskJet Office Equipment & Supplies
What is the model of inkjet cartridge? Is it 0I-HP C9362(92)? coz i cant install in the ink, thx for reply!
Your printer uses the following ink cartridges:
  • HP 92 Black Ink Cartridge (HP part: C9362WN#140)
  • HP 93 Tricolor Ink Cartridge (HP part: C9361WN#14
  • dentifier"><span class="type">SKU</span> <span class="value">C9361WN#140</span></span>HP 99 Photo Ink Cartridge<span class="identifier"><span class="type">SKU</span> <span class="value">C9369WN</span></span> (HP part: C9369WN)
Jun 13, 2011 | HP PSC 1510 All-In-One InkJet Printer
What printer goes with these hp cartridges? Thank you
Hi, i cant match these part numbers up to anything HP. Are they possibly a compatible and not Genuine HP ink.
Aug 22, 2009 | HP Office Equipment & Supplies
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
Jul 30, 2008 | HP Office Equipment & Supplies
Hp psc 2410 all-in-one
If I had it, and i was sure that I was using known good correct 56,57 or,58 HP cartridges in the correct slot to suit and cartridge contact membrane on back of cartridge slot was clean and I still found that the HP refused to accept them, then first I would check for a common fault....
Remove both cartridges have a really close look at the bent metal spring wire that sits in both slots, it is hooked on the right hand side of each compartment by plastic tabs and s shaped bend in the wire. I've seen these break at the tabs and then when cart is inserted they put a break in the contact membrane in the back of each slot. - replace carriage assembly
Wow that was hard to explain...anyway what is left is the possibility of a broken ribbon head carriage cable (make sure it is plugged in fully if brave enough to rip apart or it may be creased torn etc, or it could be a board fault, too expensive too fix. So I would send it to heavon..
You could try ebay or something to try to find a old model that suits your new hp cartridges.....
Nov 12, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
709 people viewed this question
Ben Johnson
