Question about Toshiba MD30H82 30" TV/DVD Combo
HOW DO I CONNECT PLAYSTATION 2 TO MY TOSHIBA TV?
I connected the playstation 2 cable to the antenna outlet on the television and it's on channel 3 but nothing's happening.
    Champion:
  • 240 Answers
Ok now goto menue seting and slect auto program with your play station runing the tv set should pick up the signinal.
Posted on Jan 09, 2009
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    I need instructions for hooking my VCR to my TV set,
    using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
    good luck.
    May 10, 2011 | Philips Televison & Video
    How do i connect the playstation 3 to tv, it was connected to hd tv then we have tryed to connect to normal tv and nothing. please help
    You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
    Jan 08, 2010 | Sony PlayStation 3 40GB System
    Trying to hookup vhs analog player to hd proscan
    your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
    Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
    Have an RCA F27636BC TV. Can u hook a DVD player
    How to hookup TV
    If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
    What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
    1.) RF Modulator with Stereo Audio Inputs.
    2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
    3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
    Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
    Nov 24, 2009 | RCA F27636BC 27" TV
    Cant find channel for playstation 2
    I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
    Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
    How do I connect an analog VCR + converter box to a digital TV?
    first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
    Jan 01, 2009 | Televison & Video
    Cant connect playstation 2 to LG lcd tv
    I have a sony bravia lcd digital color tv. I want to know how to plug in my play station 2? The PS2 has a coaxial cable running from it with a side coaxial connection. Where an how do i connect?
    Nov 09, 2008 | Televison & Video
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Toshiba MD30H82 30" TV/DVD Combo Logo
    489 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
