Question about Brother IntelliFax-2820 Laser Fax
Blank line on received faxes
I cannot find the office manaul for our fax. A blank line started showing up on the faxes coming in and it blanks out needed information. I have replaced the toner but that doesn't fix the problem.
It is a fairly new machine but for the life of me, I do not know where the manual is and other office staff are about ready to throw it out.
Help!
  • 215 Answers
First off, try printing a report from the front panel. hit "reports" button and print out the help list or any of the lists. if problem is present, try taking out your drum unit, look at the top and you'll see a blue or purplish colored plastic tab. note which side its on and move the tab from side to side a few times, making sure you put tab back on side where it was. if you look down in the slot the tab rides in, you'll see some wires that look like guitar strings. if there is alot of toner on those, you might want to use canned air CAREFULLY and blow those off a little, THEN do the plastic tab thing.
hth,
razors
Posted on Jan 12, 2009
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
May 07, 2013 | Sharp AR-M355N Copier
Blank lines across fax
blank lines across fax: if you get it when receive its from the sender but if when you send or make a copy you should clean properly the scanner unit with alcohol and cotton, its the trace of corrector liquid
Oct 12, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Outgoing fax was received as blank
Make sure that you sent the fax face down.
If all your faxes are sent blank, there may be a problem with the scanner. Try making a photo copy placing the page face down, if your copy comes out blank then the scanner is finished.
If your photocopy does not come out blank then the problem is on the other end and not your machine.
Thanks,
Pat
Aug 16, 2010 | Brother IntelliFax-2820 Laser Fax
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
If we send afax than it is coming blank at another
make sure you are placing the document in the feeder correctly. some faxes you have to send it face down others you have to send it face up.
Aug 06, 2009 | Brother Office Equipment & Supplies
Fax will not print test page comes out blank
Try another cartrige or clean the contact points of your print head.
Jul 29, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
Fax comes out blank at the receiving fax machine.
This type of fax is "toy" buy a laser fax an get rid of all your problems
May 26, 2009 | Canon FAX-JX200
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
