Question about Durabrand DWT2405 24" TV
When using the remote hit the wrong button now tv is stuck on cc with numbers on screen will not do anything else
I held the power button in for 20 seconds and it cleared the problem.
the tv is just fine
Posted on Jan 11, 2009
Sony Bravia stuck on Bravia screen
"Bravia Screen". Not sure what you mean. Is it in maintenance mode?
Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
DISPLAY - 5 - VOLUME + TV POWER.
When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
Hope this helps
Mar 10, 2013 | Televison & Video
On my TV certain shows (Craig Furgerson, Oprah, The View)on different networks,a black rectangle, about 1/3 of the picture, appears. I cannot remove it.
That box appears to be from the close caption feautre. If you have the original remote you can disable using the menu and go to audio functions and look for close caption to turn it OFF.
Do you have the user's guide for this TV?
If you do not, could you provide the model number of your TV?
Jul 24, 2008 | Sharp Televison & Video
Nedd to reset TV manually...... remote is not working
I have a curtis Mathis model number cm19102 . I have no remote. It is stuck on no more than 14 channels. Then the word line comes up on blank screen. How can I get it to get more channels
Jul 17, 2010 | Curtis-Mathis CM27101S TV
Innovage jumbo remote locked up my sylvania tv
I suspect you have simply switched to an unused input. If you use the original remote you can probably switch the input readily back to what you want.
Dave
Jul 04, 2017 | Sylvania SRT2232S 32" TV
I have a philips magnavox tv with the original remote. closed caption constantly (writing script)comes on tv screen, even though the remote has a cc button,i press it until cc off comes on, the cc goes off...
You're not doing anything wrong. Your TV is somehow turning the cc on "all by itself". Some bit is getting flipped inside the TV, turning the cc on.
either that or there is some sort of rf or ir interference near the TV that is mimicking the CC button on the remote.
Have you pressed the cc button on the remote, verified the cc is "off" on the TV and then removed the batteries from the remote for a while to make sure there isn't something hinky with the remote???
Feb 27, 2009 | Televison & Video
DX-R20TR 20" Round TV/DVD Combo
I'm guessing its the "CC", closed captioning. You have to turn it off, it's either in your menu or you have a button the remote saying either, Text or CC.
Apr 07, 2008 | Dynex DX-LCD37 TV
Can't turn subtitles off
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Jvc flat screen television model AV32F713 Black box on screen.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Nov 29, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
Durabrand DWT2405 24" TV Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
