Question about HP Officejet 5610 All-In-One InkJet Printer
Rplacement of ink in my HP Photosmart C7280 All in One Printer.
I have replaced the ink cart. in my printer, however my printer is not printing, in fact I cannot print anything in black, it comes up blank. There does not appear to be any type of film cover to remove. Is there some kind of re-programing I need to do?
    President:
  • 2,692 Answers
Try to clean the ink head. ths is something the printer does for you.
Here is you HP producrt support website link:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3204785&lc=en&cc=us&dlc=en&submit.y=3&submit.x=4〈=en&cc=us
Posted on Jan 14, 2009
Error code 0xc05d0281 how do i fix this
Here is the full and complete procedure you can follow to get the issue resolved Hp C7280 ink failure 0xc05d0281
for more you can call the hp support (877-690-9305)
Sep 01, 2014 | HP Photosmart C6180 All-in-One Color...
I want to disable messages about the inkcartridges.
Sadly not. The HP Photosmart C7280 insists on having a full set of cartridges installed in order to print. It does this because the printheads are actually part of the printer itself and can sustain damage if they pull air into the printhead.
The out of date message is also non-negotiable I am sad to say.
Feb 05, 2013 | HP Photosmart C7280 Laser Printer
I have hp photosmart printer,i used remanufactured ink coz cheap the print ok,then lately the print starts blerd someting like not enough black ink.i replaced the blank ink to original hp but the quality...
Bre carefull when using other than original ink in your printer.
The material used, is not the best (that's why the price difference), and end up clogging the small printheads.
I wish I had better news for you.
Don't forget to rate this answer if it helps
Oct 16, 2010 | HP Photosmart C7280 Printer
HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
May 13, 2010 | HP Photosmart C7280 Printer
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
Error 0xc18a0105 - ink faillure for HP c7280-help
Go to our web site at : www.ccl-la.com/ and click on the printer service section. We have a walk thru that will get you back going. The problem you have is caused by air in the ink feed tubes and the repair guide will show you how to do a feed tube purge.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 23, 2009 | HP Photosmart C7280 Printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
My HP Photosmart C7280 does not recognise refilled cartridge.
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Jun 15, 2009 | HP Photosmart C7280 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
60 people viewed this question
Ben Johnson
