Question about Microsoft Xbox 360 Console
Ip address failed
It has been connected with ethernet cable and systems page it says its wierd but ip address failed
  • 30 Answers
You can simply go to the network settings on the 360 and manually set the ip..You might be having an ip conflict, or where two things on a network have the same ip.
Posted on Jan 10, 2009
Ethernet cable network doesn't work on my MP4000
You can use wifi OR ethernet, configure in user tools. -Carl
Mar 26, 2014 | Ricoh Office Equipment & Supplies
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have a Belkin N-Router and I was wondering how to connect it to my modem because the cable it has connects only to where the modem's ethernet cable is located when i just run my modem, and there is only...
plug the one ethernet cable from the modem into the router wan port . The modem will have an ip address note this and then change the ip address to one higher than the modem for the router's ip address and change the ip address in the router to make the gateway ip address the modem ip address.
Disable the DHCP server in the Router iIf the modem has an active DHCP server in the router.
Plug the rest of your network into the other router ethernet ports.
Feb 24, 2018 | Toshiba DOCSIS Cable PCX2500...
Fails to connect
try to reset by pushing the button in the back then run the setup wizard by accessing your routers page via the ip address if you do not know your routers ip address plug it into your computer with an ethernet cable open up your command prompt and type in ipconfig then enter and look for your default gateway
Mar 28, 2010 | D-Link DIR-300 Wireless Router
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Lost ip address so can't connect to wireless
If you are able to connect to the router via Ethernet cable, connect, go to the gateway ip address and you can retrive the IP address info from the routers configuration page.
Good Luck.
C2Solutions
Jul 30, 2009 | Acer Aspire One A150-1006 Notebook
PS3 (80GB) Obtain IP Address : Failed, Help?
Try swapping the ends of the ethernet cable between your PS3 and the router. Otherwise, try a different ethernet cable. Also check that there are lights on by your ethernet port on the PS3 and the router.
Mar 31, 2009 | Ubi Soft Entertainment Tom Clancy's...
Internet connection failed
please check the ip configuration using system preferences in network option if its set to automatic or manual if automatic check the cable betwin your system and the network hub switch or wall socket is fine try also using another cable ...
if the status in your left hand side shows green that means cable is fine if have and ip address and is set to manual please check with your network administrator or it guys to check for proper ip address and gateway address..
there is like very rare chance for the network card in the system to go faulty afyter its mac
thanks and regards
thanksan nd
mos
Dec 26, 2008 | Apple iMac G5 Desktop
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
