Question about SanDisk Sansa Clip MP3 Player
Charger doecnt work properly
The sansa clip will not charge because It wil connect and then disconnect repetatively without stop Please Help!
  • 8,596 Answers
On your computer, go to Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager --> and uninstall the item marked MTP device. It will be a bit tricky b/c the Sansa will cut in and out during this process.
Uninstall all Sansa software, and reinstall the clean version from Sandisk's website.
-Tha Mp3 Doctor
Posted on Jan 10, 2009
This isn't a problem (I hope) but my Sansa clip didn't hold a charge for very long. Can I use my cell phone charger to charge it? It fits the connection fine.
Yes, assuming you're referring to the connection at the end of the Sansa cord and not on the Sansa itself. The Sansa can be charged by any USB device or port that puts out sufficient current.
Dec 06, 2010 | SanDisk Sansa Clip MP3 Player
Can i use an ipod charger to charge my sansa
Having gone over a month without a response, I assume this is no longer a problem.
Apr 29, 2010 | SanDisk Sansa Clip MP3 Player
I tried to charge my sansa clip with an ipod mains charger and now it is dead!
You can try and reset your sansa and see if this fixes the issue.
Connect the proper USB cable to yoru Sansa the Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Charging my SanDisk Sansa Clip MP3 Player
You will definitely need to get that USB charger cable.
Dec 09, 2008 | SanDisk Sansa Clip MP3 Player
My sansa mp3 player wot turn on
Actually there's none so think about buying a new charger and if it's not working then re-write to me so that I can help you more.
Sep 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB won't transfer songs
I had a similar problem with with one of my mobiles, so not sure if it applies in this case, check the ports, and make sure the device is connected to the correct usb port that the pc has allocated to your portable device (sansa clip)
Sep 17, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa clip
You need the latest firmware update from Sansa' website - may require a restart of computer after performing.
Apr 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2g breakdown
Get the firmware update from Sansa's website, and then restart your computer.
http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
