Question about Ricoh Aficio CL5000 Laser Printer
Problem Ricoh cl 5000
My printer show this mssage:
remove paper standard tray
please help me for this problem
tank you
vahid ghaffari
This is indicating that the standard output tray is full.
There is a photosensor on the side of the tray - try cleaning it. otherwise the sensor is faulty.
Posted on Jun 23, 2009
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Reset paper tray
Need to know model of copier
Jan 14, 2014 | Ricoh Office Equipment & Supplies
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Standard Try Full
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Good luck and please rate me, thanks.
Sep 05, 2008 | Ricoh Aficio SP C811DN-DL Printer
Got problem with aficio250
Another thing that can happen to cause a jam when you are printing on there is to make sure that the paper size if correct and matches the trays you are printing to. That condition will happen if the printer tries to print a legal size page and you only have letter paper installed in the trays.
Check your settings in the printer control panel to make sure that the trays match and are correct.
Make sure that the green paper setting knobs match the correct tray size as well.
Jun 19, 2008 | Ricoh Aficio 250 Copier
GESTETNER DSc 38
it may be one of two problem, to start off with try using one of the other trays or the manual feed. to see if it's just that tray or the machine. you may need to cancel all jobs in the printer before starting and also keep the main tray open. let me know what heppens.
Thank You,
Mikey
Mar 19, 2008 | Ricoh Aficio AP3800C Laser Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL5000 Laser Printer Logo
226 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
