Question about Samsung SC-D365 Mini DV Digital Camcorder
High pitched noise, then ejects tape
After about 10-15 minutes in use it makes a high pitched noise and beeps then ejects the tape. When I try to insert the tape again, it will not take it and pops it back out. I get a "d" and arrow messsage, which I don't know what this means. It seems like it may be overheating. It is practically usless now that it will only run for 10 minutes at a time.
  • 3 Answers
Hi friends. (Excuse my poor English). Well, i bought a SCD364 Samsung CamCoder that is physically and mechanically exactly as scd363. My scd364 also have the same problem. Because the warranty has expired, i discovered a solution. The problem ocurs due to a missing calibrati?n at tape motion mechanism then when the cam goes heat, the motor grazes with another part of the mechanism that this located very near (wax)causing a metallic noise, eating the battery and, finally the blinking "D" eject signal. I amazing when discovered that the solution is to open the tape compartment and place the opened camera infront of the air conditioning machine by 2 minutes in order to cool it. Once cold, the camera is ready to play or record again without noise and blinking "D".
Posted on Aug 05, 2007
SOURCE:
High pitched noise
High pitched noise usally happens when the suction pancake fan fins become loose on the shaft.Usallythere is two or more sandwiched on the motorshaft .. Matter of taking the tin split casing apart and check and tighten :^/
May 11, 2009 | Bissell 3750 Lift Off Bagless Upright...
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The orange tape on the bottom of the ionization bars
There being two strips of orangey tape at the bottom of the rods wipe clean the two thin wires stretching the length of the ionic breeze each time you remove the filter elements to clean the filter. Seems like these wires may be emitting the audible high pitched noise if dirty.
Frank
Jul 12, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Ejects Tape after high pitched noise
Jun 04, 2007 | Samsung SC-D365 Mini DV Digital Camcorder
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Samsung SC-D365 Mini DV Digital Camcorder Logo
103 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
