Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Leaking water out of the front freezer side
Water is constantly leaking water from what appears to be the front on the freezer side, also the ice will not dispense.
    Sniper:
  • 51 Answers
Empty out the freezer and remove the back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 13, 2009
Thank you so very much!!!
Posted on Apr 14, 2009
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
On our GE refrigerator, water leaks out of the bottom of the frame for the water/ice dispenser and down the front of the freezer side door. What could be causing this?
Did you just recently change your water filter? you need to flush 3 gallons of water out of it when changing the filter. if there is air in the line it'll drip constantly. If your ice door isnt closing all the way and properly sealing that also could be a source of water dripping. do you have a low of "Snowy" frost inside your freezer door at the ice dispenser shute?
Aug 05, 2013 | Refrigerators
Compartments are not real cold/ ice maker stopped working too
It sounds like your refrigerant was leaking out. There may be some settled at the bottom that would explain the frozen water on the bottom. a good appliance store should be able to find the leak fix it and add more refrigerant.
May 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
GE Profile Side by Side Refrigerator
This is probably the ice maker water feed becoming detached from the back of the appliance. This is a fault of a leaky watervalve or low pressure allowing water to drip into the feed pipe where it freezes building up until the pipe blocks where water pressure causes it to bacome detached. Change the water valve and refit the pipe ensure there are no airleaks into the freezer.
Jul 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
191 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
