Question about Tricity Bendix AW1000W Front Load Washer
Bendix 71478 Door release not working to release door
My machine door does not release except on prog.4,which is not good for the delicate clothes
Posted on Jan 13, 2009
Tricity bendix user manual
I have never failed to find a manual online. Go to bendix web site and search model.
Aug 22, 2014 | Washing Machines
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
Is there an emergency door release on my bendix washing machine?If so where is it?
No there isn't. The door will now open until until the wash cycle is finished
Jan 14, 2011 | Tricity Bendix AW1000W Front Load Washer
I want a complete door for aw850 tricity bendix washing machine
Hi
Can you please give me a product number for this model as there are two or three versions of door.
The product number will start ENr No: 9.................. Possibly found on the inside of the door, a label on the front of the machine next to the door seal or inside the filter flap.
Regards
Aardvark Repairs
aardvark.repairs@btinternet.com
Nov 18, 2009 | Tricity Bendix AW850W Front Load Washer
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
Bendix Washer/Dryer WDB 1074T
Well well well - Welcome to the Bendix Club!
Here is the secret!
Push all 4 buttons in!
Turn on the Cold water only!
Set the first dial on 3 dots before the GREEN #12
Set the second dial to snow or cold
Set the third dial to one dot after the green 7....
If this doesnt work...the something is wrong with the machine!
Or email me.
Apr 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Bendix washer-dryer door won't open
if you remove the panel in the front lower right hand coner of the washer you should be able to feel around in there for a plastic cord. pull the cord to manually unlock the door
Nov 24, 2007 | Tricity Bendix WDR1040W Front Load Washer...
How does this machine work??
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
chassg,
It is normal for the door to release after 2 or 3 minutes, its a precaution set by the machine; do not force the door. And surely the cycle must end for you to have a nicely washed clothes. Don't try to stop front loaders inbetween, less probs for you.
Nov 19, 2007 | Tricity Bendix AW1054 Front Load Washer
Machine stopped mid cycle - door light illuminated
this appears to me that you have had one problem and created another, based on what you say i guess the original fault was the pump or a blockage in the outlet system, now you have dismantled the door catch and made that a fault, if possible replace the door catch with one that is known to work, then retest to get back to original fault its a bit like "my telly doesn't wok it must be the on off switch" there's much more than the switch to anything, hope i have helped, if so rate me please
Sep 18, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
111 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
