Question about HP iPAQ RX3115 Pocket PC
Device Name not unique. This device name is already in use.
I let my Ipaq to discharged the battery over the weekend. Today, when I plugged it to my pc, to charge and sync., I chose "guess partnership" by mistake, and I started installing some programs. When I realized about my mistake, I unplugged it, and I plugged it again, and then I chose "standard partnership", when a window shows tha name of the device, and I click, the program displays the message:... "Device Name not unique. This device name is already in use. You must enter a different name for your mobile device". I don´t know what to do, since I need to sync. all my information, using Outlook from my pc.
    President:
  • 2,961 Answers
The name of the device is only what you want to call it, eg instead of ipaq call it tropflor, it's only a name in which the device is recognised by other devices and for sync purposes, but as in a pc, always back up your contacts and files, as pocket pcs are more likely to crash.
Posted on Jun 04, 2007
SOURCE:
My screen is not visible after I put my HP iPAQ HW6915 in my pocket.
very old device, nobody uses today, its obsolete really
not supported.
why ask here, , why not ask at HP.com
the real deal , HP. we are NOT HP, at fixya.
https://h30434.www3.hp.com/
a new battery? tried?
Jul 28, 2017 | HP iPAQ hw6915 Smartphone
How to conect my hp ipaq h1940 to the computer
Instructions
    • 1
      Select the "Bluetooth" icon from the Today screen of your iPAQ h1940. Click on "Bluetooth Settings." Touch the "Turn on" button.
    • 2
      Select the "Accessibility" tab from the Bluetooth menu and select "Allow other devices to connect" and "All devices." Click "OK."
    • 3
      Click on the Bluetooth icon in the upper right-hand corner of your Mac. Click "Turn Bluetooth On."
    • 4
      Select "Set up Bluetooth Device" from the Bluetooth menu and click "Continue." Select "Any Device" and click "Continue."
    • 5
      Select your iPAQ h1940 from the list of devices and click "Continue." Input the passkey number from your Mac into your iPAQ.
    • 6
      Select the type of syncs you want with your iPAQ and Mac and click "Continue."
    • 7
      Select "Browse Device" from the Bluetooth menu on your Mac and select the iPAQ from the list. Click "Browse."
    • 8
      Add or remove files from your iPAQ h1940 by clicking on them and dragging them into a file on your iPAQ or on your Mac. Close the window when you are finished and select "Turn Bluetooth off" from the Bluetooth menu.
    • 9
      Click "Turn off" on the Bluetooth icon on your iPAQ h1940.
hope it will help you..
monchi
Oct 17, 2011 | HP iPAQ H1940 Pocket PC
Unique baby boy name
How about 'iPad' ? Obviously, Apple did a lot of research on copyrighted names, before they choose 'iPad' for the name of their newest device, in order to assure that they had chosen a "unique" name.
May 29, 2010 | ArcMedia ABC of Baby Names
I have a HP Ipaq H6340. I just got it from a
seem like all we get here are dead Ipaq.
why are you messing with this old device?
try a new battery, oops that costs money.
as does repairs on a device that has zero value.
why not mess with and old android phone, that has value.
ask here, be like only one playing Ipaq now.
May 17, 2017 | HP iPAQ H6340 Pocket PC
Replacement Battery
PDA 2005 (as old as)
bad power supply ( weak)
bad battery charger chip inside.
this device has no value, really, why spend hard labor on such old tech? if compelled, buy 2 or 3 other dead 4360s ones, used off fleabay
to get one good one.
There is no PC made that will not fail.
consider this, if you had 2005 Toyoto car and the alternator went
bad , as all do about NOW. do you Boycott, Toyota.
nothing made by man lasts.
even earth is doomed, but not in 11 years.
Apr 16, 2017 | HP iPAQ h6315/h6365 Pocket PC
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
Totally Dead
I had the same issue. Got it fixed at PPCTechs at $60 + shipping. Better than buying a new device http://www.pocketpctechs.com/main~unit~HP_Compaq_iPAQ_hx4700-265~area~repairs~item~PPCDIAG~name~HP%2FCompaq+iPAQ+hx4700+Pocket+PC+Diagnostic+Service.htm
Dec 22, 2006 | HP iPAQ HX4705 Pocket PC
Lost data
The device doesn't exactly work like a computer... It needs battery power to "remember" what the user does. When you remove the battery, you let it forget everything. It's like how your car stereo loses it's memory channels whenever they do battery related work. What I would HIGHLY suggest, is set Activesync to do a full backup EACH TIME the device connects (it's in Tools, Backup). THEN, when he loses the information, you do a full restore. That being said -- to do a "reboot" just push the reset button (small hole on bottom left side grip) with the stylus. If you want a more thorough reboot, it's safe to just take the battery out for a few seconds. I do this about once a day.
Sep 14, 2005 | HP iPAQ h6315/h6365 Pocket PC
Just "turned off"....
Was it charging over the weekend? If not, try to recharge the device again... Those devices would on occasion drain the batter overnight -- didn't happen all the time and was apparently caused by unusual software/applications combinations... The battery could be going bad again as well.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
81 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
