Question about Emerson EWL20D6 Television
Not picking up Digital signal from box but can receive it analog
I have a converter box and a brand new antenna that is digital ready and is placed in our attic. Our tv is not very old. I can pick up stations on the tv through the antenna but when I turn on the convertor box I am not able to pick up those stations. We live near a radio tower. Could this be hindering the reception? We have tried moving the antenna but no luck.
  • 362 Answers
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
Posted on Jan 09, 2009
    New Friend:
Go to-
- menu
- option
Then ensure correct country is selected.
You're welcome.
Posted on Jan 27, 2013
What would happen if I hooked up a analog to digital tv converter to a scanner
The scanner would not be able to decode the digital TV signal. You would hear "buzzing", which would be an aglomeration of the digital TV signal. It would be competely incoherent.
Sep 15, 2014 | Electronics - Others
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Since the anologue signal was lost i canot retune my goodmans 22'' to pick up any digital channels. It seems to search for them on a blank blue screen then comes up with check aerial. Any help would be...
When the change was made from Analog to Digital was finally made it made all Analog Televisions obsolete none of them can receive a digital signal. You can get a converter box that you attach your antenna to and the output of that box hooks where your antenna used to go into your TV. With a converter box the box will receive a Digital signal, process it and present it to your Television in an analog form (what previously would be off standard broadcast). That is your only hope of continuing to use your older Television.
May 29, 2010 | Televison & Video
My tv won't pick up all channels since going digital. says signal is 62 percent. we have an arial extension could this be the problem.
If you live in the United States it is a problem since going digital. Analog signals are not broadcast anymore and your antenna is designed for analog signal, not digital. Now that the DTV Transition is completed, analog TV sets need additional equipment -– a digital-to-analog converter box –- to receive over-the-air television. Analog sets equipped with a converter box will display the digital broadcasts, but not in full digital quality. The box can be purchased almost everywhere. I hope this helps and good luck!
Nov 11, 2009 | Televison & Video
No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
Feb 19, 2009 | Insignia Digital-to-Analog Converter for...
The TV station just ran a test and our Jenson JE2043 in our motorhome does not receive the new digital signal which becomes effective in February. What do we need to do to be able to receive the digital...
You'll need one of the new converter boxes and possibly a new antenna. The US Gov't has been issuing $40 coupons toward the purchase of basic converter boxes, and some places have set prices so that you basically get them free. You can get up to 2 coupons from
Once you have the converter box, you leave your TV on channel 3 (or 4, depending on how you set it) and do your channel changing with the box.
With the new digital broadcasts, signal strength is more important than with analog. You might need to upgrade your antenna if all you have is a small pair of rabbit-ears. The only way to know for sure is to see what channels the box finds with your current antenna. There are a bunch of different indoor antennas to choose from if you need one, and outside antennas as well if you really need the pull.
The downside to all this is that you may wind up with fewer channels to watch, depending on your area. If you were able to get a fuzzy but watchable picture on analog, the station may not be strong enough for digital. You don't know 'til you try it. The picture quality of the DTV signal is much better, though.
Hope this is helpful...please feel free to rate my answer as you see fit.
Dec 17, 2008 | Audiovox JE2043 20 in. EDTV-Ready LCD...
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Converter Box Problem
That just means that stations you can't pick up while the box is on are not broadcasting digital signals yet. Most will be after February.
Oct 29, 2008 | Insignia Digital-to-Analog Converter for...
RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
Feb 10, 2008 | RCA P52939 52" Rear Projection Television
Emerson EWL20D6 Television Logo
722 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
