Question about WYSE WT9650XE 512MB/512MB LCD INTERG (90206830) Network Terminal
Washing machine my hotpoint washing machine is showing an error f8 and i reseted it from the back(takeing the plug out) but it still displayed the error can anyone help me please thankyou
  • 15,935 Answers
F8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
THE BOARD IS PROBABLY FAULTY
F08 indicates pressure switch stuck on full.
Unplug the appliance from the wall socket.
Take the top off the machine.
Locate the pressure switch, you can identify it by the thin tube attached to it.
Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
Refit the tube and try the machine again.
If still doing it, unplug again and follow the tube down.
This end will be attached to the pressure chamber.
Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
Reassemble and try again.
If after this it's still faulty you'll need to start replacing parts.
I'd suggest trying a new pressure switch first.
Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
My hotpoint wf840 is displaying f-12 and wont start. Whats wrong with it?
  • F12 - Communication error
  • A thing to do is reset machine to do this unplug for 5 mins and plug it back in if still does it then check the wires into the pcb board to see if wires have come loose or water is on it hope this helps
Jan 06, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ariston washing machine display F8
Go HERE to read about this error code for "all-in-one" models
Dec 30, 2011 | Neff V4380X0 Front Load Washer / Dryer
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
Wd640 hotpoint washer dryer the time display is
It can be the timer processor is fault and is not accepting any other program than one that is set into. remove plug and remove control board , clean and reset with tight connections, check the processor section, solder the IC and associated sections, now set back and set the clock and try once again after cancelling - pressing stop for few seconds.
If the fault stays it is problems in the timer control PCB,but it might change with prolonged resetting ,if there was dirt inthe PCB.
Sep 25, 2010 | Hotpoint Washing Machines
Hotpoint aquarius wd440 showing f12 error code how can i fix it
F12 - Communication error a thing to try is resetting the machine to do this turn machine off at plug for 5 mins then back on and start a cycle and see if it happens again. hope this helps.
Nov 08, 2009 | Hotpoint WMA64 Front Load Washer
Machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint washing machine WF860 F-08 error, does anyone know how to fix this
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
hope this helps
Sep 29, 2008 | Hotpoint Washing Machines
Hotpoint aqxxd169
take the top of the washing machine with the 2 screws on the back pull the top backwards. keep the power or ull get electrucated now ull see white plugs just simply press them in or if that doesnt work try
and click the circuit board back in
hope this helps u out
darren
Mar 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Computers & Internet Logo
118 people viewed this question
Top WYSE Computers & Internet Experts
Archie Ferrarini
Archie Ferrarini
Daniel
Daniel
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
