Question about Jazz DV-179 Digital Camera
How to get pictures
Camera and memory card was working battery dies after the camera was charged it now says the card needs to be formatted. How do I get my pictures now?
    Problem Solver:
  • 5 Answers
Go to a store that has the machine where you can order a CD of your pictures rather than getting prints. Walgreens, Walmart, etc...
Its a good idea to buy a card reader for your type of card so you dont have to use up battery power while uploading photos to your computer. It saves a lot in batteries.
As for your battery, if you have rechargeables, you should always keep spares and only recharge when battery completely dies, dont charge just because you used it, only when it dies....this will prolong the life of your battery/batteries.
Julie
Posted on Jan 09, 2009
Flashing blue light on back of camera and it won't turn on
The little blue light on the bottom of the back side of the camera is the memory access light. As long as the light is on, or is flickering, you should not open the battery cover or the memory cover. You definitely should not remove the battery or the memory card as well.
If the light is flashing, it can indicate the camera has problems accessing the memory.
If it continues, you should switch of the camera and remove the card. Then check in an external memory card reader if all pictures are still there. Get all pictures from the card and backup to a computer. Then do a format depending on the size of the card, FAT12 FAT16 or FAT32. Replace the card and let the camera format the card again.
If you do have another memory card, first save all pictures to the computer, only then put the card in your camera to check if that card works better in your camera.
If you need to recover pictures from your card, because the computer can't read them, there are enough recover programmes around on the net. Lots are free.
Jan 30, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
When i turn on my camera, it won't read my memory card and won't bring up my photos that are already on my memory card. I put my memory card in and i go to take a picture and it says 'pictures...
If the card was one that was previously used in another camera, you can't use it in this camera without formatting it. Move the pictures to a computer and format the card via the camera (remember that all data on the card will be erased). Before formatting the card however, make sure the battery has sufficient charge as this process can take some time. Also remember to never interrupt this process as it can damage the card. The format option can be found in the settings.
Note: pictures taken on one camera can't be viewed on another camera.
Jun 23, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
I received the "clean or
Welcome to FixYa.
I have seen several question with the same issues on your camera. There where 3 possible reasons why do you received an error "clean or format card". First reason is your card was not formatted for the camera used. You need to format it first for you to be able to used the memory card. Second reason is memory card slot or the memory card itself requires cleaning. Yu can used soft and dry cloth to cleaned it, sometimes pencil eraser or any eraser can be used to clean the memory card, but you have to be careful in using it on your memory card. After you clean it, you also need to format the memory card. Third possible reason is memory card might need to replace.
Notes: All existing data, including protected pictures, are erased when internalmemory or card is formatted. Make sure that you save or transfer important data to a computer before formatting the memory or card.
Make sure that there is no card inserted in the camera when formatting the Internal Memory.
be sure that the card is inserted when formatting the Memory card.
Make sure that you have a fully charged battery or used the AC adapter.
I hope this information can help you.
Thank you for using FixYa.
Apr 04, 2011 | Cameras
I receive a "communication error"
To address the present problem make sure the camera is off before plugging in the cable either to the computer or the camera. Also make sure the batteries are up to charge, low batteries or batteries that fail during file transfer will corrupt the memory card. With batteries up to charge plug the cable into the camera and the other end into a USB port and turn the camera on. Now, I would like to suggest that you invest in a memory card reader these are fairly inexpensive and can be bought as a single reader for the type of memory card you have or as a multiple card reader for pretty well every memory card that's on the market. To use a Card Reader it plugs into a USB port and the memory card is removed from the camera and inserted into the card slot. The computer recognizes this card reader as an external hard drive and files can be transferred to your computer Hard Drive with ease. One thing you must remember with any external device and that is you need to do a safe disconnect or eject make sure the device is shut off and the file information is downloaded before you remove the memory card or the files/card can become corrupt. Okay once the transfer is completed insert the memory card back into the camera and format the memory card. Don't delete the pictures at this point Format the memory card. Every time you download the pictures to the computer Format the memory card.
Jan 14, 2011 | Canon PowerShot SX20 IS Digital Camera
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
extreme7528@yahoo.com
Oct 13, 2009 | Cameras
The Sandisk memory card in my camera says memory card full but when I try to view the pictures it says no image. My computer cant read the pictures either. I know its full because the battery died while...
The card may have been ruined if the battery died in the middle of taking a picture. If the card looses power during data trasfer it damages it. You could try formating the card or you may just need to get a new one. Be sure this is the problem before you format it. Because you will loose all the pictures on it.
Dec 12, 2008 | Cameras
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Gateway Camera DC-T50
Check memory card from computer with card reader.
If that doesn`t help.
Try formatting memory card from camera or from computer (it will destroy data on card).
Most likely your pictures are alredy lost.
Feb 13, 2008 | Gateway DC-T50 Digital Camera
Canon powershot s2 Is
I just fixed mine. Put your memory card into your computer. Right click on it. Choose format. Reformat the memory card. You WILL lose all pictures stored on it.
Before putting the memory card into your camera, do the following.
Go to MENU and choose RESET ALL.
Choose reset to original settings.
When camera is done doing so, turn camera off.
Reinsert memory card after it is done being formated in your pc.
Then your camera and memory card should work great again. I just did it on my Canon Powershot A620.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Jazz DV-179 Digital Camera Logo
51 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
