Question about SATO M-8485Se Thermal Label Printer Print Engine - P/N W08485811
New unit won't receive the print job
  • SteveMurray Apr 30, 2009
    Won't print out any of the test labels; communicates but won't print from PC. No error displayed. Just sits there.
Says error #1200.
Posted on Jan 09, 2009
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
Only prints first job - can't delete from que
Please try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
Unit won't turn on. There's power to the outlet but the reciever just won't light up! Sony STR-DE 197 It's only a couple of years old and shows no damage.
Failure of the the power source. To see if it's fixable the receiver will have to be opened and the power board tested . This job requires at least a basic experience in electronics - if you don't posses it all you can do is to look for a burned fuse or damaged capacitors. For them follow this
Sep 05, 2011 | Sony STR-DE197 Receiver
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
KM7450 Vertical Lines in Magenta
I would replace the Magenta drum unit & developer unit
Jan 13, 2010 | Konica Minolta magicolor 7450 Magenta...
It sounds like you have some bad jobs stuck inside the fax's memory. First print out a memory reference report. It will show you any bad jobs stuck in the system. Delete the memory reference jobs. Then go into set up and you want to turn off the option to store failed transmisions.
The system should store jobs while it is waiting for paper. If you have a lot of stored jobs and the memory is full it will not receive any more jobs until it can print out what is stored - so it would be normal for it not to recieve new jobs until all of the old jobs are printed.
Dec 24, 2009 | Canon FAXPHONE L80 Laser
Installed drivers and set up new unit per instructions,unit will not scan or print from any user
open the nprinter folder and confirm that your preinter is set as the default printer,try and print a test page,then send your printing jobs,good luck. eyo7
Mar 30, 2007 | Lexmark X7350 All-In-One InkJet Printer
SATO M-8485Se Thermal Label Printer Print Engine - P/N W08485811 Logo
126 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
