Question about Kenmore 63942 Dryer
Dryer motor wants to run but wont
Had a heavy load in then dryer stopped working, tried it the next morning worked for 10 min then stopped. motor tries to turn but wont when i push button to start makes buzzing noise and tries to go but wont
  • Dennis Knutt
    Dennis Knutt Jan 10, 2009
    Hey, i just tried to dry some clothes in my dryer and it is doing the exact same thing and my dryer is a whirlpool..I tried to take the cover off and mess with the pulleys and belt to see if that would free it up but no dice..I just got this dryer two nights ago and it just started doing this..If u find a solution please let me know..My girlfriend and i just moved into this apartment and just got washer and dryer so we could do laundry at home and try and save some money....Now this...Would greatly appreciate it..
    Scholar:
  • 58 Answers
Sorry about your troubles. But there is a solution to the nightmare,
What your going to have to do is take the unit apart mainly the front to expose the air duct and blower, what your looking for is something obstructing the blower like socks,underware,lint, if there is not obstruction then what you will have to do is replace the motor. good luck
dmparenti
Posted on Jan 10, 2009
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
Dryer run 10 mins then stops heatin up and spinning
if your dryer works after cool down then you may have a bad motor winding. if that is the case, replace the motor.
Feb 05, 2011 | Kenmore Dryers
GE dryer is not working. a few weeks ago the spinning slowed and it sounded like the drum(?) was too heavy and grinding and then it just stopped spinning -my husband said that the three bath mats were...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 17, 2011 | GE DCVH515EFWW Electric Dryer
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
Kenmore 80 Series Heavy Duty Electrc Dryer runs but will not heat
If it will not come on and run check and or replace the thermal cutout on the vent canister and also check and or replace the door switch.
Aug 06, 2009 | Kenmore 84052 Dryer
Dryer wont run if load is heavy, belt has cracks.
I just replaced the motor on my Whirlpool which was 12 yrs. old. The motor bearings get bad and let the rotor move off-center and bind. There is a thermal overload in the motor that shuts it off when it gets too hot.
My solution: new motor, the belt is unrelated to the problem.
Apr 25, 2009 | GE DWSR463EG Electric Dryer
Dryer stops running after 5 minutes
you may have a defective door switch.
Oct 27, 2017 | Dryers
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 63942 Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
