Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Unable to install Netgear wireless router
I am unable to install NETGEAR WPN 824 v 2 on my laptop. I have previously loaded this software on another laptop but the new laptop did not recognize the password. I reset the router and still could not access so I am trying to upload the software and perform the setup. The new laptop operates with windows vista. I recieve an error message that system cannot locate the network adapter...what would that be? I have an internet connection, not sure why I cannot upload the software and reconnect the router.
  • vbrooks610 Jan 10, 2009
    Hi - yes, you addressed the issue correctly, however I cannot access the internet on the original laptop (wired or wireless) and the new laptop can make an internet connection but wil not load the router correctly...I am obviously having a slightly larger issue than first thought. I have the manuals but need to fix my connection issues first. Thanks for your helpful suggestions.
  • eecom May 11, 2010
    Can I clarify the problem a little. I would guess you wanted to connect a new laptop to your wireless router, to access the internet, but the network key would not work?
    You then decided to perform a hard reset, returning your router to factory defaults. But you are having trouble setting up the router again?
    If this is right, I'd recommend two things at this point:
    1) If you are not doing so already, be sure to use a wired (ethernet) connection from your laptop to your router, in order to perform the setup. Do not attempt to do this wirelessly.
    2) Visit the Netgear website support page for this router, to pick up a manual, setup guide and/or troubleshooting tips for your model - if you have not done so already of course.
    Netgear provide very clear advice which will help with setup, and also clear up some of the jargon related to networking.
    For example, the network adapter is a piece of computer hardware that enables you to connect to a network (and hence the internet). An Ethernet network adapter enables a wired connection: a wireless adapter enables...well, you get the picture. :)
    If I have understood the problem correctly, hope this helps you make a start..
    President:
  • 623 Answers
This does not seem to be a problem with your router, rather with the network adapter in your laptop.
  1. Go to Start -> Settings -> Control Panel -> System -> Hardware -> Device Manager -> Network adapters.
  2. Click the "+" sign to make it "-".
  3. What is listed? DO you see your wireless network adapter? If you see a yellow "!" or a red "x", that means it is not properly installed. Try to reinstall the driver.
If you need help with that, let me know. In that case I would need to know make and model of your computer.
Also: you don't have to install any software to connect to your router. This software is simply a help to setup the router. You can always type "www.routerlogin.com" in the address bar of your web browser and manage your router from there.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 31, 2009
I'm trying to connect a netgear wpn 824 to a comcast router with windows 7
You are trying to set up the wireless router with the comcast modem, right ?
You can set up the router manually , without the disc.
Make sure that your computer is able to go online when connected to the comcast modem only.
If you have the router working already then you just need to add a computer to the network.
Click Here for step by step solution
Oct 27, 2009 | NetGear RangeMax WPN824 Router
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
Light activity
locate the black button at the back of the router. This is the switch for the blue light on top of the router.
Apr 24, 2009 | NetGear RangeMax WPN824 Router
I cannot find my wpa or wpn on my wireless netgear 824 v2
You shouldnt be able to find the WPA or WPN you would have set this when you first installed and setup your wireless netgear router. Your supposed to write it down before the installation completes I had one. There should be a saved file that Netgear saved during installation that states your password and other info.
Apr 03, 2009 | D-Link DI 514 Wireless Router (DI-514)
NETGEAR ROUTER DG834N
since the wireless light is not glowing what we can do is we can go ahead and reset the wireless router,
look at the bottom of the router and you will see the routers labelling,check where the reset button is located,it will be on the back where you have the port,use a paper clip or something that is pointed and hold it down for about 30 sec you will see that all the lights will blink on the router,leave the reset button after that power off the router for 60 sec and then power it on....check if the wireless light is on....it shud be on now..
vedhick
Feb 09, 2009 | NetGear RangeMax WPN111 802.11g/b Wireless...
Ipod touch not connecting to router
wireless router wpn = password check under your router for a passcode or somewhere on it or call your nearest internet place
Jan 08, 2009 | Apple iPod touch
Need my passphrase for my netgear wpn824 wireless router
Are you trying to setup your router? If so..
Here is a list of Netgear WPN 824 Models. :) USERNAME PASSWORD
Netgear WPN824 v2 (Netgear Firmware) admin password Netgear WPN824 v3 (Netgear Firmware) admin password
Netgear WPNT834 (NetGear Firmware) admin password
Jan 07, 2009 | Computers & Internet
Trying to hookup a wireless router to HP 1100
DSL uses PPOE, which may be different than what you had previously. Cable, for example, uses TCP/IP.
Re-set the router to defaults, and follow the instructions for PPOE, which should be in your manual or setup disk. Your ISP may have this info on their site, or you can get it at the Netgear site:
www.netgear.com
Oct 17, 2007 | 2wire HomePortal 1100 Router...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
345 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
