Daewoo DH6100P disk drive folder won't open
The disc folder won't open we press the button but it seems to be jammed
  • Anonymous Apr 12, 2009
    and the menu won't come up either!!!!!!
    help
SOURCE: RCA RTD210
I had a similar problem some time ago. In a hurry, I placed a DVD in the tray; and didn't notice that the DVD was not fully inside the tray (inside the insert of the tray). So the DVD got stuck; the only way to remove it was to open the RT210 by removing the screws located at the back of the unit.
Posted on Sep 07, 2007
eagle338
  • 4889 Answers
SOURCE: Tray will not open when I press button
The tray will have a supporting element which lifts the tray up and ejects the drive..I think probably its worn out..You just need to replace it..it shouldn't cost you much..
Posted on Nov 13, 2007
mlake33
  • 427 Answers
SOURCE: Disk drive won't open
When it makes clicking sounds, there are several possible problems;
1. The gears that operate the disk drive are stripped or broken. (offset)
2. There is something interfering the with the opening of the disk drive internally.
Solutions. (Since it is recintly purchased)
1. Return it to the store for an exchange.
2. Send it to Sony for repair. (If you complain to the manager, they will give you a free game or other hardware.)
Posted on May 09, 2008
Dipu007
  • 2110 Answers
SOURCE: Toshiba L300 - disk drive tray wont open
Take a sharp object like needle and insert into the hole below the eject button...
Posted on Nov 29, 2008
HW_Dude
  • 87 Answers
SOURCE: cd/dvd drive wont open
You could try to manually eject the CD, may be the mechanism is stuck. Have a close look at the CD tray, there should be a tiny hole, then find a paper clip with a wire diameter that nicely fits this hole and poke it in there, this will release the CD tray and open it so you can retrieve the CD.
Hope this helps
Posted on Jan 12, 2009
I am trying to repair a Daewoo DVD Recorder DH-6111P and have need of a replacement hard disk drive 80Gb PATA. I have Seagate drives in stock. How do I prepare one for use in the machine?
hi, in this page show how backup software and very useful for drive replace
http://vladikuz72.narod.ru/DAEWOO_DHR/firmware_backup/how_to_backup.htm6
The major problems are often drive support and getting the drives formatted for use. It typically can't be done using a Windows PC. Some units will auto format the HDD once it is installed (assuming a recognized and supported HDD is used) and others have data stored on the drive which must be moved to the new drive before it can be used. I've never worked with any Daewoo models and aside from Tivo units try to avoid it as it isn't typically worth the headaches.
  1. Plug the HDD from the Daewoo in your PC.
  2. Download this program: https://rapidshare.com/files/2092882716/DMDE.7z2
  3. Open the program and select the appropriate physical drive from Daewoo (Disk Management)
  4. Click: Mode> Hexadecimal. Then click Tools> Copy Sectors
    Start sector: 0
    End sector: 19999
    Destination: Click "File"
    And save where you can find it! It's probably 10MB.
  5. Click OK and after done, unplug the HDD
  6. Plugin you're new HDD and in the program click: Drive> Select Drive (you're new HDD)
  7. Again Hexadecimal mode! Look all the way down of the list. Find the number of the last block!
  8. Tools> Fill Sectors:
    Start sector: 0
    End sector: That you've searched for
    Hex: 00
    Click OK
    THIS MUST BE DONE, OTHERWISE IT WON'T WORK!!!!
  9. Now again Tools> Copy Sectors
    By source, select file and open the file you've saved in the beginning.
    Destination: Start sector: 0
    Click OK
  10. You're done!!
    Plug the new HDD in you're Daewoo product and if followed the steps.
    It will give you the Daewoo boot up logo and immediately it will pop-up say: "Formatting Hard Disk"
I have now a 750GB HDD in my Daewoo!!! :D:D
You have now the OS System (.BIN file) of Daewoo on your computer for future reasons.
user manual
http://tv.manualsonline.com/manuals/mfg/daewoo_electronics/dh6100p.html?p=1
Jul 09, 2017 | Seagate Computers & Internet
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
The disk tray wont stay closed the open/close button flashes and opens again.
It seems there might be something jamming your disc drive from completely going in, or your disc drive has fallen off the track and might need to be realigned.
Jan 20, 2011 | Sony PlayStation 2 (PS2) Console
Mac G5. Grey screen with spinning wheel. This stays liek this for an hour or so. Then get desktop but just with Hard drive folder. Can open Hard driver folder but its takes about half an hour to open then...
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica}
Check for a failing hard drive
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Sep 27, 2010 | Apple Power Mac G5 Desktop
Cd drive and burner are not working
Test the disc by using the command prompt to copy files loadTOCNode(2, 'whattotry'); Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive.
To test the disc by using a command prompt to copy files, follow these steps:
  1. Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files.
  2. Click Start, and then click Run.
  3. Copy and paste (or type) cmd in the Open box, and then press ENTER.
  4. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:\*.* HardDiskDrive:\cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder.
    Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files.
  5. If you are asked whether cdtest specifies a file name or a directory name, press F.
  6. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER.
    If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement.
Jul 05, 2010 | Microsoft Computers & Internet
Will not eject disk
Is your eject button broken? Does it click when you punch it, or goes in like the button on the board is broken?
It is either this or there is something jammed inside your system.
Video: How to open Wii Console
Check inside your drive and remove anything stuck in there causing the drive to not function correctly when ejecting.
Hope I helped!
Take care
May 09, 2010 | Nintendo Wii Console
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
Is there a driver download for imac to get my verbatim reader & writer for compactflash to work?
Hi there.
There shouldn't be a driver required for your compactflash. It should be as simple as 'Plug and Play' (meaning: plug it in, and it should appear as an icon on your desktop).
However, to clarify this for you. Please supply the following information:
1. Name and Model of the Verbatim compact flash drive.
2. Is it New? IF so; Where did you buy it from? (IF New, you may need to have it replaced with another one.)
Sometimes Drives (whether USB or not) just fail. This can be for a variety of reasons.
One way you can check your disc drive is to use the Disk First Aid utility (now called : DISK Utility) which can be located in your Utilities folder.
1. Click on the Desktop.
2. Press Command-Shift-A (opens the Applications Folder).
3. Open the Utilities folder.
4. Open the Disk Utility application.
This utility will show you what disc drives are connected (in the left of the window) and from there you can choose to First Aid (Repair) the disc Drive etc...
I hope this helps. Let me know how you go. Please rate. Regards,
Feb 22, 2010 | Electronics - Others
How to use my external USB hard drive
IF you want to back it up
in the above list you made, click view all files in folders
then highlight all the files and to the left it should say Burn To Disk
click on the burn to disk and follow the on screen instructions
Hope this helps
if not write what other trouble it has
Thank you
Fixa fan
Oct 30, 2008 | Computers & Internet
Xbox 360
tap on right above the drive if a tap doesn't work just hit a little harder mine does it every now and then it will pop open
Aug 25, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
