Question about Rockwood XR-3972 Car Audio Amplifier
Rockwood Force 1 Series MODEL# U.S 3504
All im trying to get is how to hook this up properly to get the best sound but I cant seem to find this amp
How do I install a Rockwood AMP-326 amplifier? I'd like to bridge it.
Rockwood was a very low level brand. Alot of their amps were not brigeable. If bridge able the bridge terminals should be marked (usually the positive of 1 channel and the negative of the other channel). Under no circumstances bridge to less than a 4 ohm load.
Jul 17, 2016 | Rockwood Car Audio & Video
Can i hook it up to my home sound system
You must connect the amp to a power supply capable of 12VDC at over 30 amps and either have built-in current limiting capability or install a fuse in-line with the power wire.
Jan 14, 2014 | Rockwood Car Audio & Video
Rockwood amp 5556 car audio amplifier no sound
Check an make sure your fuse is tight the one coming off the battery for your amp if that dosnt work try grounding your amp to the battery to make sure the ground is good
Nov 08, 2012 | Rockwood AMP-5554 Car Audio Amplifier
XM-2002GTW Car Amp: i have 2 dual 2-ohms solobaric speakers and im try...
I researched your amp and it looks like its not even 2 ohm stable :( the problem with these companies is they lable there amps 1200 watts MAX, that means they tested the amp in a perfect enviroment and the amp fried somewhere in the ball park of 1200 watts, your best bet is to save your money and buy a nicer amp that is two or one ohm stable... that being said the best way to wire your subs is in series
May 17, 2010 | Sony XM-2002GTW Car Amp
I have a rockwood Amp-479X, need directions to install
Hello william_pric,
Look on the speaker output terminals to see if there is an indication, usually a line between the positive (+) on one to the negative (-) on the other, with the word "bridged". If the bridging terminals are not indicated, you can always try one of the positives and the other negative. If there's no sound, it must be the other two terminals. Just be careful that you don't short the terminals, and don't crank the volume up without the sub connected. Some amps don't like an infinite load.
For an input to the amp from a stock OEM radio, your best solution is to use a "line out converter", connected to the rear speaker wires. The PAC SNI-45T shown in the link is one such device. This one includes a "remote turn-on" lead for the amp. You could use a cheaper LOC and just run 12V from an accessory lead on the truck. In this case, the amp will turn on and stay on whenever the ignition switch is in the "on" or "accessories" position. If this is objectionable, mount a SPST switch somewhere convenient and wire the turn-on wire through it.
Hope this helps.
Apr 28, 2009 | Rockwood AMP-479 2 Channel Bridgeable...
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Mastercraft Wet Sharpener; Model No 55-3504-4
I just purchased one of these machines - also without the manual (seems to be a recurring problem with Mastercraft).
I phoned Mastercraft's toll-free number (1-800-689-9928) and they apologized and said they'd mail me a manual.
Have the model # handy, and be prepared to stay on hold for awhile (took me almost 30min the 1st try, maybe 10min the 2nd).
Hope this helps.
Oct 21, 2008 | Kitchen Appliances - Others
Can I run two E.V. Eliminators (1-15 and horn...8 ohms) in series from the bridged output? What my wattage be? I have an EMX5000 powered mixer. Jim Price pocket218@gmail.com
Hi pocket218
Probably not the way to go about hooking it up. running speakers in series is not very practical with PA gear. The connections get messy to make as you need adaptor leads, and it is something that is seldom ever done.. When you use bridge mode it uses left and right channel together to drive the one output, combining the power. Best bet is to run the EMX5000 in stereo mode, and connect 1 speaker to each channel. You may have been trying to reel in extra power from using bridge mode, but the power amp stages in the EMX will only ever be able to deliver the same MAX power whether in bridge or stereo. the best way to get maximum power and sound pressure levels from the unit is to hook TWO speaker boxes to each channel, you get the combined increase in efficiency of the extra speakers and run the output stages at 4 ohms to get absolutely all the power available
If you have any questions about it, feel free to ask me, happy to talk to you further about it.
regards
robotek
Sep 11, 2008 | Yamaha Audio Players & Recorders
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
354 people viewed this question
Top Rockwood Car Audio & Video Experts
Tygh Duval
Tygh Duval
Lawrence Oravetz
bigdawg7299
Are you a Rockwood Car Audio and Video Expert? Answer questions, earn points and help others
