Question about Tools & Hardware - Others
Sanding Belt Slips Badly
I have a Ryobi 4x36 Belt/Disc Sander, Model BD4600.
Even with a new SANDING belt, it slips or stops as soon as a piece of wood touches it. The yellow gear on the right changes the position of the belt on the roller, but does nothing to tighten it. I don't see any kind of adjustment to move the two rollers further apart to tighten the SANDING belt itself. There is a screw inside the lever mechanism that allows you to change the belt, but it doesn't seem to have any relationship to make the needed adjustment.
The solution?
  • David Ford
    David Ford May 11, 2010
    Does the sanding belt stop and the motor keep running? I read the complete manual for this tool and the tensioning lever is spring loaded to tension belt. Also on the belt there is directional arrow make sure it is on properly. My thought is that it might be the drive belt slipping therefore not putting enough power to the rollers to turn under pressure. The adjustment and proper adjustment for the belt is on page 11 of the manual. If you dont have one go to Ryobitools.com and type in your model number. You want to look at the first manual it has en.pdf in the line, the others are for different languages, be patient it takes them awhile to load.
  • 154 Answers
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
2 Suggested Answers
mikeymiddles
  • 58 Answers
SOURCE: Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Posted on Jan 08, 2009
I require a charger, model # 5104-14-2. Thanks.
I do have one for sale. How much are you willing to pay for it.
I just replaced my mastercraft drill for a bosch one. I live in Canada and could sell this part to you for cheap.
Give me news.
Christian Girard
girardchristian@hotmail.com
Jul 31, 2014 | Ryobi Mastercraft Belt/disc Sander Belt...
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
May 05, 2012 | Ryobi Mastercraft Belt/disc Sander Belt...
My Hitachi Belt sander SB75 the sanding belt moves off rollers as soon as applied to work piece how do I stop this happening?
There is a belt adjustment know on the side of the sander. Turn the adjustment know back and forth while the sander is running until it centers itself.
Jan 01, 2011 | Hitachi 3 In X 21 In Belt Sander, 2 Speed,...
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
http://www.ereplacementparts.com/ryobi-be321-belt-sander-parts-c-7931_7932_15013.html
Luke
Oct 27, 2010 | Tools & Hardware - Others
Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Jan 08, 2009 | Tools & Hardware - Others
Loose sanding belt
CHANGING DRIVE BELT
  Remove the cover.
the motor pulley.
Good Luck!  Middles
Tools & Hardware - Others Logo
1,268 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
