Question about Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Hello! Just bought a Canon PIXMA MX310. I can copy, so I know the ink is fine. When I try to print, it just feeds paper through without printing anything.
-Mac OS X 10.4.11
-Cables are connected correctly.
-MX310 and MX310 FAX show up in the printer window. I have selected both and neither seem to work.
-What is the proper 'print using'? I selected canon and a huge list of options comes up...i selected the first one "Canon BJC-1000 - Gimp v5.0.0-beta2" because there isn't an option for just MX310.
-Downloaded drivers from Canon already with no luck.
Thanks for any help!!
  • Anonymous Apr 29, 2009
    Hello! Just bought a Canon PIXMA MP150. I can copy, so I know the ink is fine. When I try to print, it just feeds paper through without printing anything.
    -Mac OS X 10.4.11
    -MP150 shows up in the printer window. Doesn't seem to work.
    Thanks for any help
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
When attempting to print, my Canon MX310 seems to run fine, but the paper is blank. No errors reported, but just blank paper
Have you tried running the clean heads and prime functions. If the printer has set for a while, things may have dried out. Or, perhaps the cartridges are out of ink?
Jul 19, 2016 | Canon Office Equipment & Supplies
Canon printer pixma mx310 will print but will not make a copy. It gives message "col ink vol inknown"
> col ink vol in known
The amount of INK in the COLOUR cartridge is not KNOWN.
Replace the COLOUR ink-cartridge.
May 22, 2011 | Canon PIXMA MX310 All-In-One Printer
My Canon MX310 printer is not printing. The paper feeder is not feeding the paper into the printer. It is feeding only on one side. We are unable to print or get faxes. Can you help me out?
It seems like there are some problem with roller inside..
If you have an air gun, try to get ride of dust as much as u can.
Or if you do not have one, ple use vaccuum cleaner...(at min. power) to **** out dust.
And then try for it.
Apr 08, 2011 | Canon PIXMA MX310 All-In-One Printer
When I try to print it starts a sheet of paper then lets go of it before it prints then says paper jammed when it has failed to load a piece. I have a pixma mx310
Clean the pick-up mechanism and feed wheels with isopropil alcohol and a Q tip. These items are probably slick and not gripping the paper.
Jan 24, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
May 26, 2010 | Canon PIXMA MX310 All-In-One Printer
Trying to change from black and white printing to color on canon mx310 please please help
Go to Cannon My Printer file, Click Printer Settings, Click Maintenance Tab, Click Ink Cartridge Settings, Select the ink cartridge for printing, Hit ok.
Apr 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310-cant even figure out how to copy!
Canon PIXMA MX310 Office All-In-One Printer User Manual
here you go here is the manual for your printer hope it helps and thank you for using fixa
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
488 people viewed this question
old marine
old marine
