Question about Kenmore 44103 Side by Side Refrigerator
Amana Refrigerator leaking in the inside
My frig is top freezer and bottom frig and it is leaking from the right side. What do you think I should do
  • Anonymous Mar 29, 2014
    Freezer on bottom...top frig side by side doors unequal.How do i balance them for same height
  • 183 Answers
Defrost drain channel is almost certainly blocked in freezer, to rectify turn of overnight leaving doors open, turn on the next day 12 hours later and it should then work ok.
Posted on Dec 27, 2007
I have a Kenmore elite bottom freezer refrigerator. The unit was made by Amana according to the first 3 digits of the model number (596.76253702). The unit leaks about a qt of water. It started as once a...
I have a Kenmore elite bottom freezer refrigerator. The unit was made by Amana according to the first 3 digits of the model number (596.76253702). The unit leaks about a qt of water. It started as once a month and is now leaking every 2-3 days. I brought the frig in Aug 1009. Any thoughts? Ishqbaaz Full Episode Watch Online
May I simply say what a relief to find somebody that truly understands what they are discussing on the web. You actually know how to bring an issue to light and make it important. A lot more people should check this out and understand this side of your story. It's surprising you're not more popular given that you definitely possess the gift.Ishqbaaz Porus Drama
Feb 06, 2018 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have an Amana side by side model ARS2664BW. The unit is about 8 years old. The water dispenser on the freezer door quit working and the cooling units inside the freezer and frig are not working proper....
I did a search on Amana.com's knowledge base and didn't find anything useful regarding your two top cooling units not working.
At amana.com, I tried to download the manual, but the service was unavailable until 8/9/2010 after 8:00AM due to system upgrades.
http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=L1&Request_ReadUrl=Y
The above is a service locator for your refrigerator. Since their site doesn't seem to have a solution for this, I would call in the pros if you want to have it fixed more quickly than trying to do it yourself.
Aug 07, 2010 | Amana ARS2464B Side by Side Refrigerator
Frig is leaking water down the back wall, about 1/2 cup in 24 hr
You probably have a clogged defrost drain. When the unit goes into defrost, the melt water is intended to go down a tube from your freezer down to the bottom to a pan. if the path from the freezer gets clogged, the water will seek its own level, and drip into the refrigerator. the short quick temporary fix is to unplug the unit and open both doors, blow fan for 24 hours. You will eventually need to have this serviced by an expert refrigerator repair service, it shouldnt cost more than $150, but if you attempt on your own, you could cause expensive damage, possibly forcing yourself to buy a new refrigerator.
Apr 09, 2010 | Amana ATB1935HR Top Freezer Refrigerator
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Kenmore 44103 Side by Side Refrigerator Logo
297 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
