Question about Sony Multi-System Mini Hifi Systems / DVD Shelf System
Pushed power protect
Sony Hifi System(LBT-LX10AV),Every time i turn power on the message-pushed power protect comes up.I've tried disconnecting all speakers and left the unit off for 2hrs or more and turns it back on without the speakers connected.Still the same message comes up.Please can someone help Thank You..
  • 2 more comments
  • bmk1207 Jan 12, 2009
    Hi Nuwan,thank you so much,but the problem is I dont know what a power amp board with large heatsink is,But I will ask someone and I will come back to you.Thank you once again
  • bmk1207 Jan 16, 2009
    Hi Nuwan,ok i removed the cover so what are we looking at now,thanks
  • jaydave26 Feb 03, 2009
    still not able to solve this problem..
  • sumansaha24 Feb 11, 2009
    i have the same problem by model no is mhc-rv5. can i fix it alone..???????
    New Friend:
  • 111 Answers
Speaker protection turned on.it can be happend because of bad power amlifire section.can you remoove the powe ramp board with large heatsink.its very easy to repair.and i can help.
nuwan
Posted on Jan 12, 2009
  • nuwan chinthaka
    nuwan chinthaka Jan 13, 2009
    ITS EASY TO FIND THAT .
    FIRST OF ALL REMOOVE THE COVER.
    NUWAN
  • nuwan chinthaka
    nuwan chinthaka Jan 19, 2009
    CHECK THE supply pin and speaker output pin of the output ic for short circuit.with multimeter.
    nuwan.
Hello.. I have Sony MHCEX500 MINI HIFI Component system. There is a problem of PUSH POWER PROTECT. How can I fix it..????
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
Apr 12, 2016 | Sony Audio Players & Recorders
Tip
My sony 3 disc ex-change/mini hifi component system mhc-rg66 it keeps flashing...
First things first. The unit doesn't switch on.
- Is it plugged in?
- Is the fuse blown?
- Does it look like it's suffered damage?
It switches on, but won't play anything / the lights come on, but no sound.
- We'll start at connections. Is your MP3 player/ iPod/ CD player/ record deck plugged in correctly?
- Are the speakers plugged in correctly/ at all?
- Is it in protection mode - this is a pretty standard thing now, where the amplifier tries to deliver more than it's rated current (ie, into a short circuit), and it cuts out. The only way to fix this is to take it to a local hifi shop, who will reset it (there's usually a small fee involved). The unit will be fine after that.
------- There is no bass. ----------
A few causes for this, so there's a few solutions.
- The speakers are out of phase. This is where one speaker is wired normally, one is wired in reverse. The bass from each speaker is "opposite" and would cancel out. To solve this, Make sure the + on the speaker is connected to the + on the amplifier. There's usually a stripe on the cable to help you determine this.
Cause # 2
The eq settings on your ipod/ unit have been messed with.
Set all the equiliser settings to flat, then readjust them to taste.
Cause # 3 (nasty one)
You've blown a woofer. The explanation is this - the speakers have taken in too much power, the bass unit has got too hot and the glue holding the coil in place has melted. Usually, the woofer can't be physically pushed when this happens. To solve this, it's new speaker time. An alternative is to see if you can get a recone kit for said speaker, and try to fix the voicecoil yourself. This isn't recommended to those who are new to the idea.
I hope this helps the reader.
Chris
on Sep 27, 2010 | Sony LBT-ZX6 Shelf System
Hi, whenever i am trying to power ON my hifi...i'm getting a message error on the display screen ''PUSH POWER PROTECT'...flashing continuously. please can anyone advise what should I...
This indicates that you have a blown output amplifier or shorted speaker wire. Disconnect all the speaker wires and try to turn it on once more. If it shows the same display give it to a service
Aug 16, 2011 | Sony DAV-HDX500 System
Hey i have a sony lbt-xgr90av and when i turn it on it comes up with push power protect i just want to no if there is a reset code???
NO, the condition causing it must be resolved as it is a designed-in safety feature.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 15, 2011 | Sony LBT-LX50 CD Shelf System
Im having problems with my stereo how do i get it to unlock ive got the remote and still nothing um its very old now and hasnt been used in a very long time thought id give it a go but its flashing push...
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause forintermittent shutdown.
Jul 11, 2011 | Sony Multi-System Mini Hifi Systems / DVD...
Sony LBT-LX10AV surround sound system displays only push power protect.
good.
May 24, 2011 | Audio Players & Recorders
When i turn on my sony LBT-LX50 all it says is PROTECT PUSH POWER,and i dont know what that means so what do i got to do to fix that problem?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 15, 2011 | Sony LBT-LX50 CD Shelf System
My lbt-lx50 is saying push power protect.how do i do that
You PUSH the POWER button to turn it OFF. It's sick.
Mar 12, 2011 | Sony LBT-LX50 CD Shelf System
Why does my Sony Muteki XROSSFADE LBT-DJ2i system shut itself off when the volume get turned up?
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Feb 28, 2011 | Sony Muteki XROSSFADE LBT-DJ2i Theater...
It comes on and goes back off, and is asking me to push power pro
HiFi system goes to standby because protection circuit detects error in amplifier section, you need to take unit to qualified tech for fix.
Jul 24, 2009 | Sony LBT-W300 Shelf System
1,514 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
