Computer won't 'post' on power up.( PSU is ok)
Hello this mainboard belongs to the HP/ COMPAQ support:
https://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655
The manual:
https://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655&
You can`t find anything at the msi support site.
Do you get any picture (blue screen of death) ???
Any beep sound ???
This fault could be: ram failure,harddrive,graphic card,cpu.
Or sinply mainboard is dead.
It`s always difficult to do fault finding on a mainboard.
Many thing can go wrong.
And it will sometimes cost more
than a new mainboard or pc to solve the problem.
Ask a qualified repair shop (hp support) about known issues
with this mainboard.
Good luck
SOURCE: Power switch,reset switch,power led connections to motherboard?
Hi ramjet007;
This is strange because MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup differnently, but your JFP1 should be in the right hand corner all by itself.
Front Panel Connectors: JFP1 & JFP2
Good Luck and don't forget to leave a rating.
Thanks Mark
SOURCE: Wiring diagram and manual needed
Hi my name is Tomas and i wounder if you can help me with this problem ..i need a wiring diagram to Ms-7061 ver 1.0 can you send it to my email [email protected] best regard Tomas
SOURCE: need drivers for MSI P4MAM-V (MS-6787 v2.0)
Try here for LAN and chipset. Here for sound.
Hope this helps
Chris (ziraffa)
SOURCE: I Need MS-6712 Ver:10A Motherboard driver to download
Visit this link
Drivers - Free Download
Download Free Driver scan. Automatically and easily update Drivers.
www.DriversUpdate.org
Audio Drivers Download
Latest Audio Drivers for your PC. Free Download & 100% Guaranteed.
Device-Driver-Download.com/audio
Download Device Drivers
Install the latest PC drivers. Vista certified. Free download.
QuickPCSolutions.org/devicedownload
sodeep
SOURCE: reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Many, many thanks to Hans for his solution. I do already have this web site; but he is correct. This motherboard is in an HP Pavilion p6799uk Desktop PC, and I believed the problem to be somewhere on the M.B. I required a large, clear engineering type drawing as an aid to faultfinding on the board, but in the end I was able to manage with the HP spec drawing, which Hans was so quick to supply! (the fault has turned out to be a faulty BIOS ic. Apparently, this doesn't appear to be a common fault on this particular board (lucky me!), but the problem is solved Once again, many many thanks to Hans Pedersen and FixYa for such a quick and accurate response.
