Question about Freezers
How does freezer work
Please can you find how does freezer wok
please can you find before monday
    President:
  • 373 Answers
The link answers your question.:)
click here to know how the freezer works
Good luck with it.All the best,
sunny
Posted on Jan 09, 2009
I have a True Cooler GDM-35SL-RF. the fans are not working but the compressor is. What can I do to fix this and where on the cooler would I find the problem?
They have a support line here:
http://www.truemfg.com/24HourTech_en.aspx?language_id=1&event_id=401&from=food
Our Technical Service department is available via Internet or phone
Monday - Friday 7:30 AM - 5:30 PM CST and on Saturday 8:00 AM - 12:00 PM CST.
Via phone please call 1-800-325-6152 and ask for the Service Department
You can also use the page to ask any questions. I suspect you have a fan relay that has failed as the fans should be running anytime the compressor is running. Since all of the fans are not running that leads me to think it is a relay problem.
One thing to need to make sure is to verify that all fans.. condenser (bottom of the unit) and evaporator (inside the unit) fans are not running. If the condenser fan bottom of the unit is running and the evaportar fans are not running it could be something as simple as a door switch that has failed. Call them during business hours and I am sure they will tell you what the remedy is.... and of course.. do their very best to ensure they get to send a repair tech your way.
Thanks for choosing FixYa,
Kelly
Sep 04, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My magic chef freezer will freeze for a day and then the temperature will increase to 70 degrees. The freezer is just two years old. Is it worth having someone to come out and look at it or is it...
This is a manual defrosting freezer so the most likely cause is the temp control. Sad that is is only 2 years old but the temp control is not working correctly.
It sure sounds like it is running until it cycles off at the "I reached the cold enough" SET TEMP then never starting up again. That start up is controlled by the temp control. Call and make SURE the temp control is called the thermostat!
1-888-775-0202
  • Available 7:30 a.m. to 7:00 p.m. central time, Monday - Friday
  • The Part number is WPF24B-L and the only source is Via this link: http://www.mcappliance.com/partorder.aspx
    List Price $22.95
    Thanks for choosing FixYa.
    Kelly
    Sep 05, 2010 | Magic Chef Chest Freezer MCCF5WBX
    I lost the key for door of my kenmore frost free commercial freezer where can i purchase the key?
    Hi, here is the replacement key for your model, you can purchase it for $ 2.65:
    KEY (Freezer Door Key)
    To buy the part call toll-free at 1-888-895-1535 from 7:00 AM to 9:00 PM Eastern time, Monday to Friday and Saturday from 8:00 AM to 6:00 PM Eastern time. Mention part PS426673 (Part Select Number).
    Good Luck
    Aug 22, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
    The freezer does not cool
    dear sir /madam
    please check first your fridge,s compressor is working or not if it,s working and not getting cold then it can be low gas problem so please contact to your freezer maintenance personnel for further action i mean find out leakage and brazing that after fill refrigerant gas , after that i hope your freezer will work good .
    hope answer the question
    thank you
    please vote!
    Aug 12, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
    True upright freezer. coil fan not running.
    Let it run. Coil temperature has to be low enough for the fan delay switch to close.
    Jul 14, 2010 | True 49 cu. ft. / 1388 liter Commercial...
    Freezer is not cooling to highest capacity; things in the door are not frozen very cool to touch. I have meat on the topshelf, middle, and they are still frozen not thoughed but the vegatbles are cool to...
    Air flow is very important. Make sure the vents in the back where the air blows are not restricted. Check to make sure any of the food is blocking the door from closing all the way or in the way of the door seal.
    Take a look at the back wall near the bottom of the freezer, if you see frost build up on it you may have a defrost problem. Look for frost around the door on the inside liner or door shelves, if this is found then you have a door sealing problem.
    May 06, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
    Where to get new doors?
    your best bet is to call them
    customer service:
    Monday-Friday, 8am - 5pm Eastern
    Phone: 1.800.227.7437 or 1.800.CARRIER
    maybe they sell direct or tell you where you can go thru a distributor (local closest to you) and order by phone
    hope this was helpful
    if you just need glass try local glass replacement store nearby Just a suggestion)
    Mar 07, 2010 | Carrier 10.8 cu. ft. Commercial Freezer...
    I just bought a frigidaire upright freezer a week ago. I can't get a repair person to come look at it until monday. The freezer is cold on the bottom and warm at the top. I put water on the center tray and...
    Since this is a new freezer it should be serviced by the people who sold it to you in order to avoid any warranty conflict. The fan blades of these units are of a slip fit onto the motor shaft. It is possible that the fan blade has come off the motor shaft.
    Nov 28, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
    Freezer is running constantly and sides and top are hot.
    first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
    Dec 30, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
    Freezers Logo
    75 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Freezer Expert? Answer questions, earn points and help others
