SOURCE: Change oil in 2004 Yamaha V Star 1100 Classic, procedure?
i think the oil filter is at the front behind a round finned cover, if you find the drain plug it should be right above it, it shoud tell you how much oil it takes right next to the filler
SOURCE: where is the oil filter on my yamaha V-star 1100
On the right side of the bike (right side when ou are sitting on it) just above the rear brake lever behind a small circular plate. remove the plate and the oil filter is inside (you will easily see it). Warning---on these bikes you have to drop the front exhaust header and right floor board in order to change the oil filter unless you install a after market oil filter relocation kit. If you plan on changing your own oil it is highly recommended to install this relocation kit.
SOURCE: 97 yamaha thunderace fork oil capacity
270mls per leg, or 280 if you want a little stiffer ride
SOURCE: how much oil does a yamaha vstar 1300 hold
VSTAR 1300 HOLDS 3.38 US QTS WITHOUT FILTER CHANGE AND 3.59 US QTS WITH THE FILTER CHANGE.
Testimonial: "your answer verifies the information I had thanks for your help AL Alcantara"
