Question about Logitech Squeezebox Duet
Remote doesn't recognize squeezebox duet
We just got the duet last week and had no problem setting it up and enjoy using it. However, it seems that when we go to use the squeezebox duet the remote doesn't see it under the list of controllers and we have to unplug the squeezebox, replug it in and then the remote will recognize it. I'm thinking this must have to do with how it is turned off or we have to do something to the duet (other than unplug) to get it to relink to the remote. The instructions don't say anything about turning the unit on or off so I have no way to know if we are doing anything wrong. Help!
  • marquish943 Jan 16, 2009
    Duet worked fine for a couple of weeks either through Squeeze Network or Squeezebox Centre. Then I began having trouble connecting. Unplugging and replugging Squeezebox worked once as did selecting "Pick Player" on the Home menu. Now, the home menu does not have a choice of "Pick Player" or "Turn On Squeezebox". My computer works fine with the Linksys router.
    I also noticed that when I had "Turn Off Squeezebox" on my menu it would turn Squeezebox off momentarily and then the box would turn on again showing a blue light which would occasionally go bright white all on its own while the controller was off. However no music played.
  • music person Feb 17, 2009
    I have the same problem. I constantly have to reconnect my controller to the receiver. Please help!
I have experienced the same connectivity issues with the Duet system. My first system was sent back for a replacement within the 30 day return policy. The second unit worked considerably better but the remote controller would still sometimes completely lose the link with the Squeezebox receiver after being left in the charger for an hour or two (or just set aside a while). Firmware upgrades seemed to slightly improve the situation, but I eventually sent the controller back for a replacement. The tech rep said they've had issues with the controllers. When I asked if I needed to return the receiver as well, he said "It's the controller, we've seen the problem quite a bit."
So, it seems the wifi function on the hardware can sometimes be defective. Update the firmware on everything, and if you've still got problems, insist on a replacement unit (it will likely be a refurb).
Good luck.
Posted on Feb 07, 2009
Hi Just recieved a new wireless router with Talk Talk. I've tried to connect the Squeezebox remote and I can't access the server, the remote keeps displaying TRY AGAIN. I've uninstalled the software...
Hi !
You will have to change the wireless encryption key in order to solve this issue, if you are using WEP swap fpr WPA2 and vice versa, and no ASCII , HEX is way preferable for Squeezebox.
Thanks and have a nice day !
J -
Aug 15, 2010 | Logitech Squeezebox Duet
My squeezebox duet controller's screen is blank Could this happen if the battery is dead? We were away for a week on vacation. The controller was/is in the charger. When we came back, the screen was...
Hi King,
Yes this totally could be the issue, but it should still work on his base. In any case, contact logitech support for this issue, you ll get a replacement of the defective part if still under warranty Have a great day !
J -
Jul 31, 2010 | Logitech Squeezebox Duet
Squeezebox duet drops out
Hi, Did you try by Ethernet connection ? Does the problem reproduce ? If not the you might be too far away from the access point, Do you have any bandwith consuming application running on your network ? Does the problem happen with webradio and your tunes ? Thanks and have a great day J -
Dec 30, 2009 | Logitech Squeezebox Duet
Trying to hook up logitech squeezebox
Hi. Slimserver is not supported anymore by Squeezebox systems, now you must download and install Squeezebox server 7.5.0 This way it will install and works without problem. Thanks and have a nice day J-
Oct 17, 2009 | Logitech Squeezebox Duet
I need to connnect a logitech squeezebox to an amplifier. Not sure which inputs to plug into?
Hi, You can use Optical/Coax or RCA or JACK to connect your squeezebox to an amplifier. Thanks and have a nice day J-
Sep 26, 2009 | Logitech Squeezebox Duet
No audio coming from logitech squeezebox duet
Did you try with the different connection method at the back of the receiver?
Are you talking about the remote jack ? This is normal, it still is a beta feature. Thanks to be a bit more specific if possible, Have a great day J-
Jun 03, 2009 | Logitech Squeezebox Duet
Logitech Squeezebox Duet Remote Control not working corectly
I suggest you read the instructions to ensure you haven't missed some small detail.
If you are confident you have done everything right it is safe to assume the unit is faulty and should be returned to the retailer for replacement or refund and you should contact the retailer as soon as possible.
When a person buys something they actually are making a contract that in return for some hard-earned cash the retailer will provide an item of merchantable quality. If the item doesn't work as promised it is not of merchantable quality and the retailer has breached the contract.
Apr 16, 2017 | Logitech Squeezebox Duet
Squeezebox boom stuck in demo mode
Hi !
reset it !
Unplug the power cord , push and maintain the " + " button and replug the power cord, release " + " when you see " Factory reset ", then Fixed !
Have a gret day !
J -
Apr 17, 2009 | Logitech Squeezebox Duet
Logitech Squeezebox Duet Logo
1,813 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
