Question about Kenmore 24032\24036 Top Load Washer
Kenmore 110.92575110 top load washing machine will fill and agita
Will agitate, but will not drain or spin. I removed the pump and cleaned it , but there is no sound when the cycle gets to the empty and spin.
  • 5,911 Answers
This problem is normally attributed to a defective lid switch. If the lid switch is loose or broken the lid is not detected as being closed and the washer will not operate beyond the beginning of the wash cycle. You need to check the switch to see if it has become loose, or if the lid strike as been broken off. NOTE: If your washer is equipped with one, it will be a small plastic piece located on the lid and activates the lid switch when the lid is closed. Get back to me and let me know what you find. I can assist you in locating parts and provide instructions on how to replace the switch if necessary.
Posted on Jan 09, 2009
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Washer drained after rinsing but it will not spin in any of the spin cycles ,,, it will fill but I don't know if it will agitate or not since I don't want to have to remove the water by hand if it doesn't....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 10, 2010 | Kenmore Washing Machines
My washer filled up with water, - the filling part works. however, it won't agitate or drain.
heatman101
Aug 23, 2010 | Kenmore Dryers
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Machine not draining
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
Jan 28, 2008 | Kenmore 15864/15862 Top Load Washer
Washer agitates but doesn't spin or drain
something in your pump lean it back take hose off drain pump and clean it out
Dec 31, 2007 | Kenmore 49722
Kenmore 24032\24036 Top Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Robert Rankin
