Question about Sony SLV-660HF VHS VCR
SLV-660HV Will not load
I reassembled the Sony SLV-660HV after clearing a tape problem now the tape unit will not load and I get a error code of E4 01 15. Does anyone have an idea of what that code means. The unit actually tries to load but then it ejects. Thanks for any help. Bill
    Novelist:
    Champion:
  • 254 Answers
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Posted on Jun 05, 2007
SOURCE:
Sony slv-998hf has loose part
Look for a junker on eBay or similar. This reminds me, I have several machines I can sell for parts!
Nov 13, 2013 | Sony SLV-998HF VHS VCR
My tape was stuck in the unit, managed to free it up and noe I have an erro code of E3 on the LED screen, what does this mean?
First you must make sure you got all of the video tape out of the unit. Unplug your unit from power and check for any remaining tape. Any small piece of tape could jam your unit and give you error code E3. Once you know you removed all tape leave your unit unplugged for 5 minutes to see if it clears up the error code. E3 is a drum rotation error code and usually clears after plugging the unit back into the power. If this did not help then further repair will be necessary.
I hope this helped you out! Good Luck!
Nov 15, 2009 | Sony SLV-660HF VHS VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
I have a sony vcr model slv-799hf, with a error code displayed 30109. The tape will not rotate. Dan: dodge1989@att.net What does this error code mean?
SYMPTOM: Unit does not load or eject. RESOLUTION
Replace slider with new part number 397744203
SYMPTOMS
No playback video.
RESOLUTION
Located and removed solder short between pins 9 and 10 on IC1201.
For error codes for this model, you might need the full service manual.
Contact me at billyjones@fletchersite.com if you need this.
Mar 09, 2008 | Televison & Video
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
Televison & Video Logo
231 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
