Question about Broan-NuTone K3500 Kitchen Hood
I am looking for a replacement blower for my broan k3500 hood fan
    Problem Solver:
  • 7 Answers
Call an outstanding customer support department at:
Customer Service: 800-558-1711
Technical Support: 800-637-1453
Posted on Aug 24, 2009
How do i remove the blower wheel from a broan 684 bath fan
There are a number of YouTube videos that show how to replace the motor assembly on a Broan bath fan. Once you have unplugged the fan and removed the motor mounting plate you will have easy access to replace the blower wheel and/or the motor assembly.
Just go to You Tube and search on Broan
Sep 16, 2014 | Broan-NuTone Dryers
Blower fan is not turning
Check to make certain that there are no obstructions or objects stopping the fan. Power off the unit, check the fan. Does it spin freely, if not check to make certain that it is not stuck or otherwise stopped. The fan can easily be replaced, but usually needs a service call to do this, be sure to get a quote as the cost may exceed the $$$ to replace the entire device.
Oct 15, 2013 | Broan-NuTone RangeMaster RMDD3604 Kitchen...
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
Broan Allure range hood fan will not turn off, no matter which button is pushed.
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
May 19, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Hood operates very loudly
Often the dirt and grease will build up on the fan/blower wheel and then some of it will come off throwing the wheel out of balance... this creates an intense vibration of of course a lot of noise...
Take the hood apart and clean everything really good and check the motor bearing to make sure they are not bad...(loose motor shaft in and out or up and down)...
Then you should be quiet again...
heatman101
Sep 16, 2010 | Broan-NuTone Best by Broan K260A90CMSS...
Broan allure performance ring
Are you looking for the metal ring which goes around your blower wheel. If so, we do have it at Inventex. All it does is cut down the performance of the fan. You will also need carbon filters to absord the smell.
Call us at 1-800-363-0566 Inventex
May 14, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan fan cat h 500 housing 115v 60 c 1.5a lr 31619
Oct 13, 2007 | Broan-NuTone Best By Broan BER02IS 48"...
Broan-NuTone K3500 Kitchen Hood Logo
127 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
