Wireless Printer causing slow boot of laptop
I have bought a Lexmark X6690 wireless all-in-one printer/copier/scanner/fax. When installed it worked perfectly but once my laptop was restarted, it took over 17 minutes to boot up. The desktop appeared after about a minute, but no taskbar and no icons for over 17 mins. Using msconfig, I have found that by preventing a file called 'LexBce Server' (under services tab) from operating, my laptop boots as normal in about 1 min 30. By stopping this file from running though, it prevents the print server from operating and I have no print/scan/copy function. I bought the printer from PC World who will not refund as they say all functions work and there may be a compatibility issue. Any ideas.
  • 4 more comments
  • youngtommo Jan 13, 2009
    Paulo2, Its Windows XP with SP3.
    Windows XP Home Edition with Service Pack 3
  • youngtommo Jan 21, 2009
    Found a solution to my own problem by searching other help forums. So just in case anyone else has the same problem, copy the following link into your browser and select the correct fix for your Lexmark printer. It certainly worked for me, It downloads a program which opens a dos prompt and perfoms alterations to how the print spooler operates. It definately made the boot process of my laptop speed up incredibly.
    Ian
  • Ross K Apr 07, 2009
    Youngtommos fix was good.
    I have Lexmark X4950 and three WinXP Pro SP2 machines, two of them required Youngtommos fix for slow boot:
    ftp://ftp.lexmark.com/driver/inkjet_drivers/slowboot/32bit/
    This fix was very hard to find.
    Some keywords for the searchers:
    Lexmark 4900 X4950 X4975 slow boot slowboot problem
  • paulo2 May 11, 2010
    Which windows version do you use?
Same problem here on wo of my customer's laptops. Both running WinXP.
After hours of running around, Lexmark Tech Support suggested fix that youngtommo above posted. Instant fix!
Posted on Jan 30, 2009
Windows 7 64bit, home network. Lexmark interpret s405 all in one.Trying to scan with windows fax and scan. can printer with no problem. windows fax and scan cannot find scanner. I look in device manager...
Try to re-insert the installation disc that came with your printer. Run the disc and make sure to install the Lexmark scan driver. If you have a firewall enabled, make sure to allow all access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
May 11, 2011 | Lexmark Interpret S405 Wireless All-in-One...
No install disk
To download your Lexmark printer driver (for free), visit the Lexmark website using this link Lexmark Downloads Homepage. Enter your model number and select your operating system to start the download.
Mar 24, 2011 | Lexmark Multifunction Wireless Printer/...
I just purchased your 705 professional series wireless printer. Can I use this with my non wireless computer laptop? thanks I have a Dell Inspiron computer.
Yes, the printer can still be connected to your computer via the USB cable. Before connecting the printer to your computer, I suggest you insert the installation cd in your computer first. Run the software and follow the instructions on it. While it is installing, the software will also show you a step-by-step instructions on how to setup the printer itself. Hope this helps.
Jul 13, 2010 | Lexmark Multifunction Wireless Printer/...
Is it possible to refill ink cartridge on Lexmark x6690 printer?
Take out all cartridges, switch printer off and then on again and let printer see that there are no cartridges. Do this 5 times, it resets the cartridges. Then install refilled cartridges
Apr 08, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark x6690 4 in 1 set-up software jammed XP
Simon,
Been trawling yet more help sites and came across the following link to a Lexmark Slowboot Fix. Click the link below, select the right fix for your printer from the three shown, and install, accepting the terms and conditions. When the resuIting program installs and is run, it opens a dos window and performs some changes to the print spooler. It has made my laptop boot up in about 3 mins, which when compared to the 17 that I was previously experiencing, is like rocket speed !! My printer now works perfectly without any of the jiggery-pokery, I suggested in my last post. Make sure you are booted up with all the Lexmark stuff installed and working, so go through a slow boot, before clicking the link below.
All the best,
Ian
Jan 12, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
X6690 fax setup
Turn auto-answer off and you can manually answer fax calls by pressing 9 on your touch-tone phone. See page 22 of the Fax Guide.
Jan 04, 2009 | Lexmark Office Equipment & Supplies
Fax issues
Thanks for the response! I managed to do this myself,I was not aware that your PC must have a "phone modem" card! Once I installed one I already had on hand, it went flawlessly! Windows XP likes this printer!!! Nice "all in one" printer,for sure. I used the Lexmark to replace our Epson scanner and seperate printer, AND our clunky old fax mach. Thanks for such a helpful website. Regards, Jim
May 30, 2008 | Lexmark Wireless X4850 All-In-One Inkjet...
973 people viewed this question
jasbo
jasbo
