Question about Ricoh Aficio CL2000N Laser Printer
I have a Ricoh CL1000N & it was printing fine earlier. About 20 minutes ago I got a SC481 error
    Sniper:
  • 86 Answers
Please check the OPC belt unit (green belt) by opening the upper door. Remove it and check if it is defective and then reinsert it back properly. Switch off and on the printer.
Posted on Jan 11, 2009
Ricoh aficio cl1000n sc481 error message
sc 481 is the OPC belt error. check the opc belt unit. it is also called rum unit. i think the belt is worn out and needs replacing.
Jan 06, 2011 | Ricoh Aficio CL1000N Printer
On a ricoh aficio CL1000N, what does the error code SC922 or SC992 mean?
There is no sc922 for the CL1000N, but sc992 is a general software error. It typically shouldn't interrupt operation, but it if it does and it happens more than once, try to figure out what you were doing when it happened. Were you printing a big job? Were you printing a job with a particular font? Does it always happen at a certain time of day? Narrowing down the conditions can help to figure what is causing the error code.
Jun 30, 2010 | Ricoh Aficio CL1000N Printer
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Describe your Ricoh Aficio 1232C Error Code SC481 Problem
Right from the service manual
My best guess is belt mark blurred or missing
or image belt out of position
Feb 01, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio CL1000n Print quality very low.... not sure why. Trying to print color and it comes out very stripe-y. I used to use a Ricoh at my former office and it worked great. Everything I've read about...
the post scrip option is option but your printer might nit have installed this option .
But about the print quality you should call service to fix it here is nothing you can do
Jun 16, 2009 | Ricoh Aficio CL1000N Printer
Sc481
SC 481 is a belt mark detection error. The transfer belt on the photoconductor unit has a rip in it. Replace the Photoconductor unit.
Apr 09, 2009 | Ricoh Office Equipment & Supplies
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
182 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
