Question about Uniden Cordless Phone
CL flashing on base unit
On the number of messages display, I have a CL flashing. I don't have the manual. Also two of the three phones have no dial tone
I reset the day and time and then reset the phones by putting them in the base unit
Posted on Jan 10, 2009
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have a Ge 25942EE4-C phone and the Cl is flashing I have looked the phone over for a button to set this can you please assist me?
We had this same problem and seeing that the Manual is incorrect, I searched GE website manuals to find a different one that at least looked like the right model and found out how to clear the CL message code. This is just a time/day setting and it is to be done by the handset, not the base unit, With the handset, press the flash key, then press #8. You should now see the time flashing in the display. Adjust the time then press the pound key. Now the day is flashing in the display. adjust the day with the up arrow, then press the pound key to finish. Your base unit will announce the time and day is set and the CL is gone.... good luck
Dec 29, 2008 | GE 25942GE2 Cordless Phone System
System keeps flashing with CL
Program the clock. There are a some buttons on the back of the base unit that sets day of the week, hour, and minute.
Dec 18, 2008 | General Electric 28031EE3 5.8 GHz 1-Line...
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Reset after power outage
You just need to reset the time to fix this problem. There were three buttons on the back of the base for the day, hour, and minutes. I didn't know they were there!
Sep 07, 2008 | Uniden Cordless Phone
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
IN 120 base keeps flashing CL
- press the OK key
Jul 09, 2008 | Lands Phones
I have an Wharfedale IN120 Touch Dectr Phone with Answer Machine, on the answer machine display screen CL is flashing, I don't know why or how to clear it.
I have just posted this to answer someone else but will do it for you in case it comes up elsewhere.You need to key in the time and date again on the handset, because even though it already says the time and date on the handset its because the battery has saved the data but the base needs it re installing to date and time the messages. I unplugged mine to move it and thats when it started flashing it took me ages to work out that CL was the clock. Hope this helps I'm sure it will.
Jun 21, 2008 | Lands Phones
Code cl
Which phone is having problems? the base? one handset? All? CL... Check Line?
Jun 17, 2007 | GE 28112 Trio Cordless Phone
Uniden Cordless Phone Logo
149 people viewed this question
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
