Question about Carrier Heating & Cooling
Cant find wireing diagram for carrier 585ejw30050ca
Gas valve replacement ef32cw183 w-r is configured differently from orig valve thougths on this 5 wire setup ? are the 2/3 terminals common more details 2/3 goes to rectifier bridge and piolot coil 5 is the other end of circut 1/3 main burner coil 4/5 pressure switch old valve had single internal solenoid 3 wire proven piolet spark igniter setup
  • 3 more comments
  • waltcoolkat Jan 09, 2009
    p.s gas control sol for piolet clicks when w and heat connected gas flow at valve but none at piolet outlet or piolet outlet check port tried adjusting piolet level gas valve is on position perhaps fautly new vavle ?
  • waltcoolkat Jan 10, 2009
    have the valve wireing diagram but not the heater will check for output voltages from the heater. can you embelish on how the pressure switch (insde the gas valve) functions ? this is a redundant type valve 4 .250 connections 1 .200 connection on the old valve the smaller wire was on a common coil winding new valve is a w-r ef32cw183 or in newer valve number 36e 304 (type 24) redundant fast open 24volt white rodgers inst sheet 99ta503033e im thinking that you are correct and there is a safety holding up the gas flow since i get spark and the piolet sol clicks when i call for heat wth / red connected
    orig wire harness was as follows piolet green to mgv sol term and spark ignitor yellow from piolet to mgv sol term changes to brown to temp switch
    black wire (common to a lot of terminals) pr swithc to mgv sol term slos to ign box and 24volt xfmr other side of pressure switch goes to 24 volt xfmr (other leg) brown pr switch in old valve had small (very small) wires going to a resistor and a sort of stopper that was attached to a spring on the inside of the gas inlet to the mgv (main gas valve) in summary 5 wire valve has terminals in different locations than the replacement valve
    gas valve working ok now but excessive current draw thru thermostat opens on anticipation after 30 seconds ??
    thx rayname you were on the right track turns our i had a coil common and power feed reversed changed them to correct terminals and its working but still have problem remaining refered to above excessive thermostat amp draw will try checking for control coil shorts
  • 70 Answers
If you have a volt/ohm meter you can unplug all the wires to the valve set the meter to ohms and check to see across each terminal which have measurable resistance these should be the coil, usually the diagram is on the panel door i guess this is not the case so you will probably have to see which wires have voltage when your tstat is calling for heat also you need to make sure there are no other safety holding this circuit out let me know how you make out
Posted on Jan 09, 2009
I need the wire drawings to change from the Johnson G770, or the Fenwal 35-63J To the Honewell S8610U Universal intermittent gas ignition control.
Hello. I've attached multiple schematic diagrams for different configurations of this control. I hope one of the pix helps you delineate the different connections. The last several schematics were too large for a single screenshot so there are 2 pix for each of those schematics.
Sep 16, 2015 | Honeywell S8610U3009 Universal...
Need a wire schematic for a deep fryer gas valve elite efs 40
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 28, 2015 | Imperial EFS-40 - Gas Elite Deep Fryer -...
Location of purge valve 2001 durango
  • It will be on the drivers side by the firewall and will look lik the diagram I posted below. It loos a little different then some do so this may be why it is a little tricky to identify.
  • Hope this helps
Nov 08, 2011 | 2001 Dodge Durango
I have a paragon 8145-20 defrost timer. do you wire the compressor to the timer? I cant seem to find a wiring diagram on how to wire this correctly
Link below has wiring diagrams and wiring manuals for 240V 8145-20
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
I am not expert installing defrost timers.
According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
Wiring diagram does not show compressor wired to timer.
The cycle works like this:
Timer is running but defrost is not switched ON.
Fan is ON.
Timer switches ON and activates defrost cycle.
Fan turns OFF. Hot gas valve turns ON for defrosting.
Cycle limit switch is temperature or pressure sensitive.
Cycle limit switch reaches trip point, timer switches OFF.
Hot gas valve turns OFF. Fan turns ON.
So fan is off during defrost cycle.
Hot gas valve turns ON when timer switches ON.
Timer is switched OFF by pressure-or-temperature limit switch.
Dec 09, 2010 | Paragon 8145-20 Defrost Timer
Carrier furnace burners will not light.if i blow at the burners it will light.I think maybe bad gas valve or not enough pressure
this sounds exactly like the problem. I replaced a gas valve yesterday in a Goodman furnace that had the same symptoms. I would check it or have it checked with a manometer before you replace the valve. If your inlet pressure is right and you cant get enough pressure by turning the adjustment screw clockwise, it is bad. LP should have @11-13inches of water column coming into the vavle and an outlet pressure of 7 inches of water column. Natural gas should have @5-7 inches coming in and an outlet pressure of 3.5 inches of water column
Jan 06, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need wire diagram for 3207-121189
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=9d087afdef677010VgnVCM100000cb890b80RCRD
Search this web site. It has lots of manuals. It is Carrier site.
Hope this helps. Wiring diagrams are hard to find but I know they are there if you input enough of the right info.
Hope this helps and be patient while you search.
Nov 20, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
How to connect 440v to three phase aplit type or to the motor compressor.? it is the same diagram of 220 three phase?
If the voltage plate don"t say 220/440 you cant hook it to the higher voltage but you are right about the wiring it is the same wireing configuration
Oct 29, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I've been told that I need a new gas valve. Are they expensive and difficult to replace
Usually under $100 and easy to replace. Comes with instructions. The tricky part is knowing which wires to connect so make a good diagram of the original to match up with the new in case the wire colors are different.
Aug 11, 2009 | Jandy Lx Pool & Spa Heater - Electronic...
Trouble light blinks 3 times
Need to stat brand name of equipment, differant manufacturers use different codes. There should be a listing on the front panel or on the inside of blower door with the wiring diagram. On some Carrier type it would be a code 31 , for inducer motor (vent motor) on a gas furnace or the pressure switch not making
Apr 21, 2008 | Heating & Cooling
Heating & Cooling Logo
359 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
