Question about SanDisk Photo Album Digital Media Player
Usb flash drive will not load jpeg images
The folders appeared then it froze on loading
What kind of flash drive is it? Is there a protection switch on the device so that it will prevent accidentally deletion of files? Like a tiny switch that can move up and down that says "lock" or "unlock"?
Does your computer give an error warning window? Is the drive already full and therefore cannot hold more files?
Posted on Jan 09, 2009
Numark IDJ 2USB Flash Drive issues
use the lexar brand jump drive, they tend to work better the the dj station. i have a 64GB jump drive with 3,000 songs on it and it works great with no problems.
Jun 21, 2012 | Numark iDJ2 - DJ iPOD Mixer Docking...
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
I can`t see photo files like jpeg etc, from my flash memry (8GB) - empty folder. But, avi files are running properly. TV is Sony KDL-46HX800. Is it some upgrade or something, or what?
The TV will only detect USB Devices if it is formatted in FAT32 format.
Files from a USB device need to be compatible with the following file formats.
- Still images: JPEG format or RAW format (preview only)
- Music: MP3 format
- Video: AVCHD, MP4 (AVC) or MPEG1 format (not playable in some cases)
Make sure that you're using the compatible file formats in the USB Drive.
Also check if the USB Drive which you're using is compatible with the TV.
Click here to check the list of compatible devices which Sony recommends,
The accessible file or folder limit in a directory is 1,000 for USB. This limit includes non-supported files or just folders. Files or folders are populated based on their time stamps. Photo, music files or folders exceeding the limit will not be displayed.
Check if the above mentioned criteria meets the requirements.
Thanks for using FixYa.
Feb 15, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
I would like to use my usb flash drive to install and troubleshoot my windows xp operating system. My dvd cdrw drive is not working. I have an error stating that the explorasy.sys file is not there when I...
We are going to do this the easy way....you need a computer of course and one that has a working cd/dvd player, a flash drive and a windows installation disc. A recovery disc will not work...you need a windows installation disc.
Go to the control panel > folder options > click on the "View" tab, scroll down and UN-check the box the says "hide protected operating system files", now click the bubble above that says "Show hidden files and folders.
Now get out of the control panel and insert the windows disc in the drive.
Go ahead and insert the flash drive into a usb port and let windows recognize the device and load it. It will give the device a drive letter.
After the disc loads, it may appear on your desktop and say to install Windows....just exit the program but don't eject the disc. Open "My Computer" and look for your cd/dvd drive and right click on it. Choose "open" from the choices and a list of files and folders will appear. Select all the files except for a file that says "desktop
Copy all the files and paste them into the flash drive that you can find in "My Computer" The files from the disc will now be written to the flash drive. Once the copy is completed, the flash drive can now be used to boot the computer.
Insert the usb drive into the laptop that needs fixing and power it up. After the flash screen appears, tap the F12 key to bring up the multi-boot options. Choose USB drive and hit enter. The laptop will boot off the usb drive and initiate the Windows files.
Jun 30, 2010 | Toshiba Satellite 2415-S205 Notebook
Custom Background Images
I was using a memorex ultra speed cd-rw and did not work, but i decided to use a regular cd-r digital audio and it worked! Just creat a folder named BG and place up to 20 jpeg pictures in that folder, then place 100MB of files (Not mp3) outside the folder and burn it onto the cd and youre done!
Jun 25, 2009 | Pioneer AVIC-N3 Car DVD Player
Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
Mar 29, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Nov 17, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Lost Olympus Camedia Master 4.2 images
want to copy all my pics to camedia master
Nov 10, 2008 | Computers & Internet
How do i register my d53 to my computer so i can down load the pictutes
If finding the right software is an issue, perhaps using a USB card reader to access the images on the SD card frome the camera is an option. It's a little more effort, but works quite well and doesn't require a special driver since the images are probably in JPEG format. Just access the files on the card as though it was a flash drive or any other type of storage device.
Oct 12, 2008 | Samsung Digimax D53 Digital Camera
SanDisk Photo Album Digital Media Player Logo
222 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
