Question about Pit SSR 110CC Pro Beginner Bike
I have a pit bike and it splutters alot when i ride it
When u pull the throttle right back it splutters and doesent go
My pit bike will not keep it revs for a long time so can some one help me it is my first pit bike
Posted on Jan 28, 2009
    New Friend:
I have a m2r racing 140cc. It keeps spluttering so I'm guessing it's the carb. How easy is it to clean it? Also there's petrol coming from the carb what does that mean? Thanks
Posted on Nov 08, 2014
    New Friend:
  • 25 Answers
Clean carb qnd air filter and cleed ur spark plug olso ur air mix might need set
Posted on Jul 26, 2014
    Problem Solver:
  • 13 Answers
Try and tke the air filter off ! carb mite need cleaning
Posted on Jan 15, 2009
Do you need insurance to ride a pit bike offroad/on quarys/and tracks and also do you need a license and how old do you have to be to ride a pit bike
Hi, Declan the answer to this question is way above my pay grade for this situation, I would call or visit my local DMV or dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.motosport.com/blog/dirt-bike-insurance-do-i-need-it
Do You Have To Have License To Ride Dirt Bike
Legal laws riding pit bikes INFO Pit Bike Club
SSR Pit Bike Specs
Pit bike Wikipedia
Nov 13, 2017 | Pit Motorcycles
I do alot of offroading on my pit bike, because i do pit bike extream up hills and down hills which is fun sometimes its muddy so i let the tyre down a bit to get grip now the problem i have is it keep...
OK this ought to help you, I pulled it from this site: http://www.dirt-bike-tips-and-pics.com/dirt-bike-tires.html
  • Air pressure: When riding in sand or mud, lower the air pressure to around 10psi in the rear and 11-12psi in the front. This allows more surface area on the tires to contact and grip with the sand. For harder conditions on motocross tracks and trail riding over stones, branches e.t.c, inflate them up to around 13psi, 14psi max. If the air pressure is too low over hard terrain, you run the risk of causing a puncture or damaging the RIMS. Don't tighten the nut (on the air piece) to the rim. It's not meant to be tightened. Back it off to meet the valve cap once you've got the air pressure right.
  • Sep 11, 2011 | 2007 KTM 450 EXC Racing
    09 TM EN 300,after the bike is warm and ridden for around an hour or so,it splutters and misses under quarter throttle intermittantly..Clean carby jetted well..Electrical issue im thinking?Anyone...
    Check the gap on the points and check to see if they're pitted or burnt. You might just need to clean them with some emery cloth or something similar. If they're pitted or burnt, they need to be replaced
    Jun 18, 2011 | TM Racing EN 300 Motorcycles
    I have a 110cc pit bike and when i kick the kicker it does nothing and when i pull the throttle back it clicks what can i do to solve this problem realy appreciated
    could be a range of things only way to really know is to take it apart and look for blockages on fuel inline or damage to piston.
    Jan 02, 2011 | Pit SSR 110CC Pro Beginner Bike
    To keep my engine running i have to pull the throttle obviously to rev it, else it the engine cuts out, and when i ride it splutters and cuts out, so i kick down a gear n it starts again but then dies...
    has the bike been sitting for some time? Sounds like a classic case of gummed up low speed jets in the carbs. Pull the carbs and clean then out.
    Mar 11, 2010 | 2000 Aprilia RS 125
    110 pit bike my pit bike starts but when i pull da
    your spring might have broke on your throttle needle take apart have a look
    Nov 11, 2009 | RTO Pit Bikes
    Hi mt pit bike is spluttering under acceleration i have tryed to adjust air screw with slight difference but it is still not smooth under power. bike is fk1 125 dont know if valve clearence would be the...
    Your bike may be jetted too lean. A common problem in these days of overzealous EPA regulations. You can tell if when you've cranked your throttle wide open and it splutters, if you back off on the throttle about 1/8 to 1/4 turn, it clears up. This is indicating that it is jetted too lean. When you close the throttle slightly, the fuel is being metered by the main jet and by backing off on the throttle a bit, you're cutting back on the air, thereby bringing the mixture closer to what the engine needs. Try rejetting the carb, Go up one or two sizes on the main jet, one step at the time.
    Now, it could be too rich as well. If it splutters and blows black smoke out the exhaust, it either jetted too rich or the float level in the carb is set wrong.
    Take care of the simple stuff first before rejetting the carb. Make sure your spark plugs are the correct ones and they are not fouled from overusage of the choke or enricher. If you allow the bike to "warm up" with the enricher on, plug fouling is common with this practice. I get the bike started and as soon as it will run without the enricher or choke on, I turn it off and keep the bike running with the throttle. Don't foul as many plugs that way.
    Nov 09, 2009 | 2008 Yamaha Yamaha G5
    I just got a 110 ssr pit bike. is the back brake
    It should be below. Not to sound rude, but I think you could have figured this one out yourself. You sound like a smart guy.
    Thanks for using FixYa.
    Aug 12, 2009 | Pit SSR 110CC Pro Beginner Bike
    Xsport 110 pit bike
    check the 4 stroke oil if it starts to splutter at half throttle
    Nov 08, 2008 | Cycling
    Pit SSR 110CC Pro Beginner  Bike Logo
    956 people viewed this question
    Top Pit Cycling Experts
    john h
    Mack Baxter
    Are you a Pit Cycling Expert? Answer questions, earn points and help others
