Question about Whirlpool AWG329 Front Load Washer/Dryer
Whirlpool awg 338 washer
It suddenly stops heating the water, does not seem to rinse anymore and stops in the centrigual cycle.. Since it all suddenly appeared, I guess it is not 3 seperate problems, but one
  • edwin t w Jun 04, 2007
    I'll try, thanks
  • Anonymous Mar 24, 2014
    having problems getting it to start cycle, but having got it going and completed its cycle the door won't release
    Sergeant:
  • 236 Answers
Initially check the element for continuity then check that any part of the wiring has not come off. if the water does not heat up it may not be advancing the timer to continue with the later stages of the wash, ie waiting for the stats to say the water is warm enough. tone.
Posted on Jun 04, 2007
Whirlpool awg 736
possible water level switch at fault
Jul 16, 2013 | Washing Machines
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Whirlpool washer will not stop at end of cycle
Turn off extra rinse switch or pull wire going to it. If water is slow the water valve may have a restriction in it. Remove hoses and check for blockage in the hose screens.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
Won't drain water for rinse
your lid switch is defective..replace onthejob
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool AWG329 Front Load Washer/Dryer Logo
983 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
